InlineQuerier
Creates SQLite database tables from incoming features, executes SQL queries against them, and outputs the results as features.
Jump to Configuration
  • Performing SQL queries on any features, whether or not they originate from a SQL supporting format.
  • Executing complex queries and joins without multiple transformers
The InlineQuerier creates a temporary SQLite database, and creates a table for each input object that is connected to it. In the parameters dialog, you may create any number of SQL queries that use these tables. Each query defined has an output port paired with it, and the query results are output as features.
Input table definitions can be easily created by connecting to the Connect Input port. They can also be defined by importing the schema of any feature type in the workspace, whether connected or not (though the table will not be populated unless the feature type is connected). Any number of tables may be created.
SQL queries can involve any and all tables and columns defined in the input. In particular, multi-way joins can be executed, advanced SQL operations involving nested Select statements and advanced predicates can be used, and the input tables can be used by multiple queries.
See the SQLite documentation for a detailed reference on the SQL Select statement syntax that is supported.
  • Consider using the InlineQuerier to replace multiple FeatureMergers. The InlineQuerier allows its input data to be reused multiple times in a single transformer, whereas if multiple joins are to be done with a FeatureMerger, multiple FeatureMergers must be employed and copies of the features sent to each. On the other hand, there is some overhead for the InlineQuerier to load the underlying SQLite database. Using a single InlineQuerier instead of several FeatureMergers also simplifies the workspace.
    Unless only a single FeatureMerger is needed in a workflow, the InlineQuerier may be a better choice. Older workspaces with multiple cascading FeatureMergers may experience a performance improvement by replacing the FeatureMergers with a single properly configured InlineQuerier.
  • If all the data to be queried already resides in a SQL-capable data source, consider using the SQLExecutor or SQLCreator instead, as queries will be more efficient when performed by the source database.
  • If the query is a simple join between features and a database source, and the key(s) are indexed in the database, consider using a DatabaseJoiner for more efficient processing.
Dialog Options - Tables
Processing Behavior
Not Applicable
Feature Holding
Not Applicable
Dependencies None
Aliases
History
Search for all results about the InlineQuerier on the FME Community.
