CKANConnector
Connects to a CKAN open data portal using the CKAN Action REST API. Supports reading and writing CKAN Dataset and Resource metadata, downloading of file-based Resources, and uploading files to the CKAN FileStore. Does not support row-based operations against CKAN DataStore Resources.
Jump to Configuration
  • Browsing and downloading public datasets hosted on a CKAN portal
  • Creating or updating metadata and file-based Resources
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies
Aliases
History
Search for all results about the CKANConnector on the FME Community.
