GoogleCloudStorageConnector
Accesses the Google Cloud Storage file storage service to upload, download, or delete files and folders or list file/folder information from a Google Cloud Storage account.
Jump to Configuration
  • Manage datasets on Google Cloud Storage by uploading, downloading, and deleting files and folders
  • Transfer a file's contents (such as XML or raster) into or out of an attribute in FME
  • Read downloaded Google Cloud Storage data using the FeatureReader, or upload data written by the FeatureWriter to Google Cloud Storage
  • Retrieve file and folder names, paths, links and other information from Google Cloud Storage to use elsewhere in a workspace.
The GoogleCloudStorageConnector uses the Google Cloud Storage account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the file storage service.
Depending on the specified action, it will upload or download blobs and attributes; list information from the service; or delete blobs from the service. On uploads, link attributes can be added to the output features. On List actions, file/folder information are added as attributes.
  • This transformer cannot be used to directly move or copy files between different Google Cloud Storage locations. However, multiple GoogleCloudStorageConnectors can be used to accomplish these tasks.
  • The FeatureReader can access Google Cloud Storage directly, without using the GoogleCloudStorageConnector. In this case, a permanent local copy of the dataset will not be created.
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies Google Cloud Storage Account
Aliases
History Released FME 2019.0
Search for all results about the GoogleCloudStorageConnector on the FME Community.
