AttributePivoter
Restructures and regroups incoming features based on specified Group by attributes and calculates summary statistics to form a Pivot table output.
Jump to Configuration
  • Calculating statistics on tabular data
The AttributePivoter receives features with attributes, restructures and regroups them based on specified Group by attributes, and calculates summary statistics based on a designated Attribute To Analyze in order to form a Pivot table output.
Like the StatisticsCalculator, the AttributePivoter groups features according to selected attributes, and computes statistics on a single attribute for all features in each group (Grouping by rows). Beyond this, the AttributePivoter allows for the order of these row grouping attributes to be specified so that a logical nesting of additional summary rows can be generated. In addition, the AttributePivoter also allows for new attributes to be generated dynamically based on the unique values of a selected attribute (Grouping by Column) with values populated by statistics performed on the resultant groupings.
Note: Because the AttributePivoter generates attributes dynamically, you must set any writer feature types to dynamic mode if you want to include these attribute in the output. This is described in more detail in Result Grouping and Tabular Structure.
  • The AttributePivoter can only be used to analyze one attribute at a time. If you need to analyze more than one attribute, consider the StatisticsCalculator.
Dialog Options - Tables
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies None
Aliases
History
Search for all results about the AttributePivoter on the FME Community.
