ReprojectLengthCalculator
Converts a given length from one coordinate system to another.
- Determining text heights and widths
- Reprojecting distances stored as attribute values
The ReprojectLengthCalculator receives features with geometry and reprojects a given distance from one coordinate system to another.
The transformer starts with two points. One is the first coordinate of the input feature’s geometry, and the second is calculated from that point using the Original Line Angle and Original Line Length. Both of these points are reprojected from the Source Coordinate System to the Destination Coordinate System. A new length is calculated from the reprojected points and added to the output feature as an attribute value.
Original Line Length is in the Source Coordinate System’s ground units. The length may be provided as an attribute, expression, constant, parameter, or conditional value.
The Original Line Angle may be provided as an attribute value, constant value, expression, user parameter, or conditional value.
Both the Source and Destination Coordinate Systems must be specified explicitly.
Reprojections are generally performed using the FME (CS-Map) library, however, this transformer will honor the Workspace Parameter Reprojection Engine, and will use the Esri Reprojection Engine if it is selected there, with or without an Esri product being installed.
Z values are not supported.
This transformer assumes all coordinate systems are Cartesian.
In this example, we have a CAD file containing traffic signal locations and labels. The original file is projected as UTM83-10, but we want to know what will happen to the label height if we reproject to BCPOLY-83.
Note that the label's autocad_text_size value is 2.
The features are routed into a ReprojectLengthCalculator.
Note that three format-specific attributes have been exposed - autocad_text_size, autocad_text_string, and autocad_rotation. This was done in the Autodesk AutoCAD DWG/DXF Reader parameters, Format Attributes, so that we can access their values.
In the parameters dialog, we set Original Line Length to the exposed autocad_text_size attribute, and Original Line Angle to 90 degrees (pointing north).
Both the Source and Destination Coordinate Systems are specified explicitly.
The Reprojected Length attribute is named _length (default).
The output feature has a new attribute - _length - containing the value of the reprojected line length.
Note that the Coordinate System has not changed and is still UTM83-10. The feature itself has not been reprojected, its geometry not altered. The reprojection to BCPOLY-83 has only been used to calculate the _length value.
- This transformer requires that features have geometry to provide an initial coordinate. Non-spatial features will not produce valid output. To create geometry for non-spatial data with coordinates as attributes, consider using a VertexCreator.
- To calculate the reprojected length of a feature with line geometry, consider using a Reprojector (or other reprojection transformer) and LengthCalculator.
Coordinate System Support
Library |
FME (default) or Esri |
Library (External Links) |
Sweden |
Sweden |
Switzerland |
Features with geometry.
Features with a reprojected length value added to an attribute.
Original Line Length |
Specify a distance, in the Source Coordinate System’s ground units. |
Original Line Angle |
Specify an angle, in the Source Coordinate System. Angle is measured counterclockwise from horizontal in degrees. |
Source Coordinate System |
Specify the coordinate system of the input features. |
Specify the coordinate system the Original Line Lengthis to be reprojected to. Note that the feature itself will not be reprojected, and this parameter is only used for calculation of the Reprojected Length Attribute. |
Reprojected Length |
Name the attribute to contain the reprojected length value. |
Dialog Options - Tables
Search for all results about the ReprojectLengthCalculator on the FME Community.
