MRF2DShortGeometryRemover
Note: Support for the MRFClean transformers is no longer provided as of FME 2022.0. Please contact Safe Software for alternative transformers that can be used to transition your FME workspaces.
Removes features that have lengths smaller than the specified tolerance, if Short Geometry Action is set to Remove.
Each feature that is output through the Cleaned port will have a new attribute "mrf_clean_status" added to specify whether the feature was modified, created, or unchanged in the cleaning process. The possible values of this attribute are "Modified", "Created" and "Original".
If Short Geometry Action is set to Flag, such features will not be removed, but for each one a point, label, or circle (depending on the value of Flag Type) will be output through the Flagged port.
Group Processing
If selected, each group of features with the same values in the Group By attributes will be processed separately from other groups.
When All Features Received: This is the default behavior. Processing will only occur in this transformer once all input is present.
When Group Changes (Advanced): This transformer will process input groups in order. Changes of the value of the Group By parameter on the input stream will trigger processing on the currently accumulating group. This may improve overall speed (particularly with multiple, equally-sized groups), but could cause undesired behavior if input groups are not truly ordered.
There are two typical reasons for using When Group Changes (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Group By usage - not performance considerations.
The second possible reason is potential performance gains.
Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains).
Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Group By with When All Features Received may be the equivalent and simpler approach.
Note: Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order.
General
Cleaning tolerance is used as the default tolerance unless the Feature Tolerance Attribute is specified and valid. The minimum tolerance allowed is 0.0.
The number of layers used in cleaning the data is determined by the number of different tolerance values of input features. Features that have the same tolerances are processed as being on the same layer.
You can set the Short Geometry Action to either Remove or Flag features.
This parameter sets the flag type as a point, label or circle, if Short Geometry Action is set to Flag.
For each feature that is smaller than the specified tolerance, this parameter sets the flag type as a point, label or circle, if Short Geometry Action is set to Flag.
This transformer performs the same operation as the MRF2DCleaner with the Delete Short Geometries parameter set to Yes and no other options selected. See the MRF2DCleaner for more details.1 Note that the circle/label flagging is an added option in this transformer.
Dialog Options - Tables
