LineBuilder
Connects input point features in the order they enter, forming linear or polygonal features.
The output features will contain a merged set of attributes from all the features that were connected together, where the value for an attribute in the resulting feature comes from the first feature that had an attribute with that name that was part of the resulting feature.
For some datasets, it may be necessary to use a Sorter to order the data correctly before it enters this transformer.
Example
If the resulting feature is a single point, it will be output through this port.
If the resulting feature does not begin and end at the same point, it is output through this port.
If the resulting feature forms a ring (begins and ends at the same point), it is output through this port.
Any features that are not points or lines are output through this port.
| Group By |
The default behavior is to use the entire set of input features as the group. This option allows you to select attributes that define which groups to form – each set of features that have the same value for all of these attributes will be processed as an independent group. If only one point feature was received with a given value for the Group By value, it will be output as a Point. If the feature output forms a ring (begins and ends at the same point), it is output as a Polygon. Anything else is output as a Line. |
| Complete Groups |
Remove Duplicate Points |
If Yes, duplicate coordinates from input features are removed. That is, if two point features, both at (0,0,0) are input, one point at (0,0,0) is output. If No, duplicate coordinates from input features are not removed. That is, if two point features at (0,0,0) are input, a line is output with two coordinates, both at (0,0,0). |
Accumulation Mode |
If Drop Incoming Attributes is chosen, the output feature will not preserve any input attributes. If Merge Incoming Attributes is chosen, the output feature will merge all input attributes. If Use Attributes From One Feature is chosen, the output feature will get attributes from only one input feature. |
| Generate List |
When enabled:
Dialog Options - Tables
Keywords: "point joiner" "line creator" PointConnector
