FMEServerJobSubmitter
Submits FME jobs to be run on an FME Server. A job consists of a workspace (housed within a repository on an FME Server) together with values for each of its published parameters. This transformer submits one job per feature which enters it. Any published parameters of the server workspace will be given values as specified in the transformer, or taken from attributes of the feature which enters it.
The FMEServerJobSubmitter submits jobs via the FME Server REST API and does not make use of the transformation services.
Dependencies
This transformer requires an FME Server connection.
Features that submitted the requests to the server and successfully completed. This port is only visible when Wait for Jobs to Complete is Yes.
Features that submitted the requests to the server, but failed to complete successfully. This port is only visible when Wait for Jobs to Complete is Yes.
Features that successfully submitted the requests to the server. This port is only visible when Wait for Jobs to Complete is No.
A single feature which details which jobs were submitted and which succeeded. This feature contains the following list attributes: _submitted_job_ids{}, _succeeded_job_ids{}, and _failed_job_ids{}.
Features that failed to submit the requests to the server.
Connection
You can connect to an FME Server in one of the following ways:
Specify a web connection to an FME Server. Web connections can be reused in multiple workspaces, and connection parameters are hidden in the workspace. For more information, see Using Web Connections.
SAML Authentication
SAML (Security Assertion Markup Language) authentication is not available for these FME Server transformers:
See SAML Configuration and Automations for more information and alternatives.
When checked, you must specify the connection parameters to the FME Server manually. The connection parameters are visible in the workspace. To connect, specify:
Enter a URL to access FME Server. You may need to contact your System Administrator for the URL.
Provide your FME Server credentials.
Note: You can click the Status hyperlink to ensure that the FME Server connection has been successfully established.
Submission Mode
If this parameter is set to In Sequence, the transformer will submit each request as soon as it receives an initiating feature. If Wait for Jobs to Complete is Yes, the transformer will wait for the job to complete before processing the next feature.
Note: A sub-engine process will be spun up to run any child jobs. This Engine will follow the naming convention Engine_<n>@<ID> where <ID> is the Job ID of the parent job and <n> is the name of the Engine the parent is running on.
If this parameter is set to In Parallel, the transformer will wait until all input features are received, then send a set of requests for each unique combination of Repository and Workspace specified. If Wait for Jobs to Complete is Yes, the transformer will wait for all of the submitted jobs from one set of requests to complete before sending the next set.
Note: A minimum of two engines is required to use the FMEServerJobSubmitter when the submission mode is In Parallel and Wait for Jobs to Complete is Yes.
If this parameter is set to Yes, then the transformer will wait until the job is completely processed by the server before proceeding. In this case, the initiating feature is output via the Succeeded port if the job successfully ran to completion, and will have these attributes added to it:
- _job_id: The integer ID the server assigned to this job.
- _numFeaturesOutput: The number features that were output by the job.
- _priority: The priority assigned to the job.
- _requesterHost: The name of the machine hosting FME Workbench that submitted the job.
- _requesterResultPort: The port on the host machine through which results are returned.
- _status: Job status indicator; can be SUBMITTED, QUEUED, ABORTED, SUCCESS, FME_FAILURE, JOB_FAILURE or PULLED.
- _statusMessage: The translation result message.
- _timeFinished: The time the job finished .
- _timeRequested: The time the server received the job request.
- _timeStarted: The time the server started processing the job.
All times are in YYYYMMDDhhmmss format.
The feature will be output via the Failed port if the job did not run to completion, or to the <Rejected> port if the job could not be submitted, and will have these attributes added to it:
- _job_failure_type: Holds one of "Connection or Server Problem" or "Translation Failed". If the latter, then the following attributes will also have values; otherwise, they are empty.
- _statusMessage: The error message returned from the server explaining why the request failed.
- _timeFinished: The time the job finished.
Note: _job_id is included only if the job failure is related to an error during translation. If the job did not run due to a connection or server problem, then _job_id is not included.
If this parameter is set to No, the transformer will output the initiating feature as soon as the job is submitted to the server. In this case, the initiating feature is output via the Submitted port if the request was successfully submitted, and only the _job_id attribute will be added to it. If the server could not be contacted or the job submission otherwise failed, then the feature is output via the <Rejected> port, and the _job_failure_type attribute will hold the "Connection or Server Problem" value.
Job Parameters
Specify the FME Server repository that contains the workspace you want to run.
Specify the workspace to run for each feature that enters the transformer.
Any published parameters of the workspace to be run appear here. For each one, specify the value to pass when the workspace runs. To refresh the parameters from FME Server, click the refresh icon.
Advanced
Defines the order in which the job will be executed on the server.
Job Priority is not available when connecting to FME Server 2018.1 or newer.
When connecting to earlier versions of FME Server and while disconnected, this parameter is available. Priority values range from 1 to 200, where:
1 - Highest
100 - Normal
200 - Lowest
If supplied, submits the workspace to the specified Queue to follow the associated Engine Assignment Rules. If left empty, the workspace will be submitted to ‘Default’ Queue, unless the submission mode is In Sequence and Wait for Jobs to Complete equals Yes, in that case, FME uses an internal system queue with the name context-id-<UUID>.
For more information , see Queue Control.
The time, in seconds, after which a job that is waiting in queue does not execute. If the job does not execute before this time is reached, it remains in the queue until it is ready to execute, but execution is not attempted. This directive is useful for time-sensitive jobs that you do not want to run after the specified time is exceeded.
The time, in seconds, a job will remain in the running state. This directive ensures that a job does not hang and block an FME Engine indefinitely. The minimum allowable value is 1.
Dialog Options - Tables
Transformer History
This transformer was previously named the ServerJobSubmitter.
Keywords: ServerJobSubmitter
