DMSCalculator
Calculates degrees, minutes, and seconds (DMS) from a decimal degrees value provided as an attribute.
Calculating the DMS (degrees, minutes, seconds) equivalent of latitude and longitude decimal degree values.
The DMSCalculator receives any feature with an attribute containing a valid decimal degree value, and converts that value to degrees, minutes, and seconds. The results are added as attributes to the output feature.
If an invalid (for example, non-numeric) value is received, the translation will fail.
In this example, we have a dataset of world cities. The features have decimal degree coordinates as attributes. We want to convert those values to DMS.
The features are routed into a DMSCalculator.
In the parameters dialog, Input Attribute is set to LATITUDE. Attribute names for the converted values - degrees, minutes, and seconds - are left with their defaults.
The output features have three new attributes, containing the converted values.
To perform a reverse conversion, DMS to decimal degrees, use a DecimalDegreesCalculator.
Features with decimal degree values stored as attributes.
Features with degrees, minutes, and seconds values added as specified in parameters.
Input Attribute |
Specify the source attribute containing the decimal degrees value. |
Degrees |
Name the attribute to contain the resulting degrees values. Note that if the decimal degrees value was negative, the resulting degrees value will also be negative, but the minutes and seconds values will be positive. |
Minutes |
Name the attribute to contain the resulting minutes values. |
Seconds |
Name the attribute to contain the resulting seconds values. |
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the DMSCalculator on the FME Community.
