About the Reader and Writer Gallery
Tools > Browse Readers and Writers
The Reader and Writer Gallery lists all formats supported by FME.
It includes the following information:
Column Definition
Description
Full format name
Short Name
Common abbreviation for the format
Extensions
Lists file extension(s) associated with the format
Type
Indicates whether the format is a file- or directory-based format
Read/Write
Indicates whether the format is a reader, a writer, or both
Coordinate System
Indicates whether a custom coordinate system is associated with the format
Licensed
Some formats require that you obtain special licensing, or specific versions of FME. This column indicates whether your FME is licensed to read/write the format
Search
Enter a keyword or a partial text string to filter results.
Custom Formats
  • Create a new format using the Custom Format wizard.
  • Import a custom format and add it to the gallery.
  • Edit an existing custom format.
Close
Close the gallery.
Details
Click on a format, then click Details to display the technical documentation for the format.
