PointOnLineOverlayer
Performs a point-on-line overlay. Each input line is split at its closest place to any point within the specified point tolerance, and attributes may be shared between related points and lines (spatial join).
Jump to Configuration
- Splitting lines where they overlay points
- Identifying lines that intersect with a point
- Identifying points that fall on a line
The PointOnLineOverlayer compares points and lines, splitting the lines where a point falls on (or within a specified distance of) the lines. Each resulting new line may receive the attributes of the points that matched the original line, and points may receive attributes from the lines (a spatial join). Features (points and lines) also receive a count of the number of matches encountered.
Aggregates can either be deaggregated before processing or rejected. Intersections between linear features are not computed.
Example: Overlaying points on lines
In this example, we perform an overlay of rapid transit stations points on rapid transit lines. The source data, as seen here, contains three individual transit routes, each one a single line feature.
The station points are close to the lines, but not right on them - generally within a meter.
The stations are connected to the Point input port, and the routes are connected to the Line input port.
In the PointOnLineOverlayer parameters dialog, we enter a tolerance of “5” - meaning 5 meters, as these datasets are in a UTM projection, with ground units in meters. We also choose to merge attributes.
The transit lines are split where they encounter a station within the specified tolerance, as shown here by randomly coloring the output line features. Attributes are shared between the points and lines, as in these point attributes for Renfrew Station, which now has a new attribute indicating that it overlaid the Millennium Line.
Output Lines receive attributes from all of the points that the original unchopped line encountered - see Usage Notes for more detail.
- Where point geometries are expected, Point Cloud geometries are not supported.
- Chopped Lines output via the Line output port receive the attributes of all points that matched the original input line (if a list is enabled). All points that the original line encountered are included - not only the endpoints of the new line segment.
To obtain attributes from points matching only the ends of the new line features, use a second transformer (consider another PointOnLineOverlayer, or a NeighborFinder).
Z Values and Measures
If the input Line features have measures and/or 3D coordinates, measures and elevations (z values) are interpolated and assigned to points according to the selections made in the Attribute Accumulation parameters.
If Attribute Accumulation Mode is set to Drop Incoming Attributes, the measures and z values will be ignored. If it is set to Merge, Prefix, or Replace with Single Incoming, the appropriate values will be calculated and assigned to the points. If a z value is added to a 2D point, it will become 3D.
Spatial Transformers Comparison Matrix
SpatialFilter
Yes |
Testing for the existence of spatial relationships between two sets of features, and routing them according to whether they pass or fail the test(s).
SpatialRelator |
Yes |
Yes |
Yes |
Identifying the nature of spatial relationships between two sets of features.
AreaOnAreaOverlayer
Yes |
Yes |
Yes |
Yes |
Finding polygon overlaps and extracting them into new geometry.
LineOnAreaOverlayer
Yes |
Yes |
Yes |
Yes |
Finding intersections between lines and polygons, and splitting the lines where they intersect with the polygons.
LineOnLineOverlayer
Yes |
Yes |
Yes |
Yes |
Finding intersections between line features, splitting them, and generating new line geometry as well as points representing the intersections.
PointOnAreaOverlayer
Yes |
Yes |
Yes |
- Point and Area
- Text and Area
Identifying points that fall within polygons, and merging attributes between them
Yes |
Yes |
Yes |
Yes |
Point and Curve
- Text and Curve
Identifying where points fall on lines, and splitting the lines into new geometry.
PointOnPointOverlayer
Yes |
Yes |
Yes |
- Identifying points in the same location (within a tolerance), and merging attributes between them.
Intersector
Yes |
Yes |
Yes |
Yes |
Finding intersections between all input features, regardless of geometry (including self-intersections), splitting features, and creating new geometry.
Clipper
Yes |
Yes |
- Point
- Text
- Curve
- Area
- Solids
- Raster
- Point Cloud
Comparing features against a set of Clipper features, and splitting the features at or along the Clipper boundaries. Outputs both new and untouched geometry, identified as either Inside or Outside the Clipper.
NeighborFinder
Yes |
In some cases |
Yes |
Identifying the nearest other feature(s) to each feature being considered, either in another set of features or within the same feature set.
TopologyBuilder
Yes |
Yes |
Yes |
- Analyzing spatial relationships between features to compute topology, splitting features and creating new geometry representing topologically significant nodes, edges, and faces, with associated attributes.
The Effect of Spatial Transformer Choice on Performance
When there are multiple ways to configure a workspace to reach the same goal, it is often best to choose the transformer most specifically suited to your task.
Point
Point features against which the lines will be compared.
Line
Line features against which the points will be compared.
Point
Point features, with attributes added according to transformer parameter configuration. Geometry is unmodified, unless z-values have been extracted from lines.
Line
Line features which have been split at the location closest to matching points, with attributes added according to transformer parameter configuration.
<Rejected>
Features with invalid geometries will be rejected and output via this port.
INVALID_POINT_GEOMETRY_TYPE
INVALID_LINE_GEOMETRY_TYPE
INVALID_LINE_GEOMETRY_VERTICES
INVALID_GEOMETRY_DEGENERATE
Group Processing
Group By
The default behavior is to use the entire set of features as the group. This option allows you to select attributes that define which groups to form. |
Group By Mode
Process At End (Blocking): This is the default behavior. Processing will only occur in this transformer once all input is present.
Process When Group Changes (Advanced): This transformer will process input groups in order. Changes of the value of the Group By parameter on the input stream will trigger processing on the currently accumulating group. This may improve overall speed (particularly with multiple, equally-sized groups), but could cause undesired behavior if input groups are not truly ordered.
Considerations for Using Group By
There are two typical reasons for using Process When Group Changes (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Group By usage - not performance considerations.
The second possible reason is potential performance gains.
Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains).
Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Group By value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Group By with Process At End (Blocking) may be the equivalent and simpler approach.
Note: Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order.
General
Overlap Count Attribute
The Overlap Count Attribute added to output linear features holds the number of point features that were near to it. The Overlap Count Attribute added to output point features holds the number of linear features that the point was near to.
Point Tolerance
The Point Tolerance value is compared to the distance from the lines to the points, and the lines will be segmented if the distance is less than or equal to the Point Tolerance value. When such a match occurs, the attributes of the segmented lines are merged with the points and the attributes of the points are merged with the lines.
Aggregate Handling |
Choose how aggregate geometries are to be handled.
Deaggregate: Decompose aggregates into their individual components.
Reject: Do not process aggregates and output them via the <Rejected> port.
Merge Measures
If Yes, any measures that exist on a line will be added to matching points. Measure values are determined according to the Treat Measures As parameter.
If both point and line have measures of the same name, the point's values will be overwritten by the line's values.
If No, no measures will be copied, and any existing measures (on points or lines) will be output unchanged.
Treat Measures As
This parameter determines how measures are computed:
- at new intersection locations on lines, and
- when adding measures to points if Merge Measures is Yes.
Continuous: The new measure value will be calculated, interpolating based on the nearest measures.
Discrete: The new measure value will be copied from the nearest measure.
If attributes on the incoming and original feature share the same name, but are not geometry attributes that start with fme_, then they are deemed conflicted.
Note: On the PointOnLineOverlayer, Attribute Accumulation applies to the measures on a point in a similar way to how it applies to the attributes on a feature.
If measures on the point and line share the same name, then they are deemed conflicted.
The resolution of conflicted measures on points occurs in the same manner as the resolution of conflicted attributes on features. It is resolved according to the Accumulation Mode and Conflict Resolution values.
Accumulation Mode
Merge Incoming: The original feature will retain all of its own un-conflicted attributes, and will additionally acquire any un-conflicted attributes that the incoming feature has. This mode will handle conflicted attributes based on the Conflict Resolution parameter.
Prefix Incoming: The original feature will retain all of its own attributes. In addition, the original will acquire attributes reflecting the incoming feature’s attributes, with the name prefixed with the Prefix parameter.
Replace with Single Incoming: The original feature will have all of its attributes removed, except geometry attributes that start with fme_. Then, all of the attributes from one (arbitrary) incoming feature will be placed onto the original.
Conflict Resolution
Use Original: If a conflict occurs, the original values will be maintained.
Use Incoming: If a conflict occurs, the values of the incoming will be transferred onto the original.
Prefix
If the Accumulation Mode parameter is set to Prefix Incoming, this value will prefix attributes and measures that are being added to the original feature from the incoming feature.
Generate List on Output ‘Point’
When enabled, adds a list attribute to the Point output features, and the attributes of each line matching an output point are added to that point's list.
‘Point’ List Name
Enter a name for the list attribute.
Note: List attributes are not accessible from the output schema in Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used.
Add To 'Point' List
All Attributes: All attributes will be added to the output Point features.
Selected Attributes: Enables the Selected Attributes parameter, where specific attributes may be chosen for inclusion.
Selected Attributes
Enabled when Add To 'Point' List is set to Selected Attributes. Specify the attributes you wish to be included.
Generate List on Output ‘Line’
When enabled, adds a list attribute to the Line output features, and the attributes of each point matching an original input line are added to each output line created from it.
‘Line’ List Name
Add To 'Line' List
All Attributes: All attributes will be added to the output Line features.
Selected Attributes
Enabled when Add To 'Line' List is set to Selected Attributes. Specify the attributes you wish to be included.
How to Set Parameter Values
Text Editor
Arithmetic Editor
Dialog Options - Tables
- Add a row
- Remove a row
- Move current row up one
- Move current row down one
- Move current row to top
- Move current row to bottom
- Cut a row - delete and copy to clipboard
- Copy a row to the clipboard
- Paste a row from the clipboard
Cut, copy, and paste may be used within a transformer, or between transformers.
Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output.
Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies |
Aliases |
History |
Search for all results about the PointOnLineOverlayer on the FME Community.
