Bufferer
Creates a buffer zone of specified size around or inside input geometry.
Jump to Configuration
  • Creating fixed size zones around features, such as rights-of-way or setbacks
  • Determining spatial relationships based on proximity
  • Creating variable size zones around features to represent attribute values
The Bufferer accepts 2D point, curve (line), and area geometries when the Buffer Type is Area (2D). All geometry types are accepted when the Buffer Type is Solid.
Points and curves may be expanded, creating surrounding polygons or solids with points offset by the specified Buffer Distance in the specified units. Areas may be expanded or shrunk, using positive or negative Buffer Distances, but solids require positive Buffer Distances.
The attributes of the original features are retained, and the buffer is output, discarding the original geometry.
A selection of end cap and corner styles is available.
An optional list attribute may be created, holding multiple attributes for grouped or aggregate input.
  • This transformer creates buffers that are of equal width on either side of a linear input feature. To create offsets to either the left or right-hand side of a feature, use the OffsetCurveGenerator.
  • Areas will be buffered on one side only - externally for a positive Buffer Distance, and internally for a negative Buffer Distance.
  • Output area buffers will always have a Right Hand Rule orientation.
  • This transformer may produce unexpected results when input areas are self-intersecting.
Dialog Options - Tables
Processing Behavior
Dependent on Dissolve On Attributes parameter. If:
Feature Holding
  • Dissolve On Attributes Unset: No
  • Dissolve On Attributes Set: Yes
Dependencies
Aliases 3DBufferer, GeographicBufferer
History
Search for all results about the Bufferer on the FME Community.
