PointCloudConsumer
Reads point cloud features for testing purposes, including any accumulated point cloud operations. No additional operations are performed, and nothing is done with the features.
Jump to Configuration
- Performance testing or benchmarking point cloud processing.
- Debugging point cloud processing.
- Testing point cloud feature validity.
The PointCloudConsumer receives point cloud features and reads all of their data at their current state in the workspace. It does not perform any new operations on the point clouds.
FME handles point clouds in a “delayed evaluation” model. A point cloud reader reads essential information about a point cloud, but does not read the actual point contents until it is absolutely necessary. Transformer operations are accumulated until the results are needed, often being held until the features enter a writer. At that point, the required data is fully read and processed.
This is intended to optimize performance - for example, if a point cloud is both clipped and reprojected, FME will optimize processing by not reprojecting data that falls outside of the clip boundary and is ultimately discarded.
The PointCloudConsumer transformer forces this read to occur, and any accumulated operations are performed as the features are read. Nothing is done with the read features, and the transformer will not improve performance - it simply emulates the effect that reading the data would have, wherever it is placed.
It can be used to test workspace performance without configuring writers, and can also be useful for debugging point cloud processing workspaces with multiple accumulated operations. It may also be used for point cloud geometry validation, as it will reject any non-point cloud features.
Note: Though the transformer has a parameter that can be used to adjust the way in which the point cloud is read (Block Size), it is primarily of interest for internal Safe performance testing and is not generally useful in a production environment.
Example: Estimating point cloud processing time
In this example, we are building a point cloud processing workspace.
The source datasets are four LAS point clouds, totaling approximately 387 MB, which need to be reprojected, combined, have some component values calculated, and then be passed along for further processing.
As all of these operations will be accumulated until they are required (such as enter a writer), we cannot yet determine how long it might take to process this.
A run of the workspace as it stands is very fast, an indication that the point cloud operations have been held for later processing.
To get a more accurate idea of how long this will take, we add a PointCloudConsumer after the three point cloud processing transformers.
In the parameters dialog, we keep the default settings.
Running the workspace again, we can see that it will take more time to fully read and process the point clouds, with the accumulated operations applied.
- The Enable Feature Caching option in FME Workbench should be disabled to obtain more accurate processing benchmarks.
Point Cloud Transformers
PointCloudCoercer
Converts point clouds to point or multipoint geometries, optionally retaining attribute and component values.
PointCloudCombiner
Combines features into a single point cloud. Point cloud and non-point cloud geometries are supported.
PointCloudComponentAdder
Adds new components with constant values to a point cloud.
PointCloudComponentCopier
Copies selected component values onto either a new or existing component
PointCloudComponentKeeper
Keeps only specified point cloud components, discarding all others.
PointCloudComponentRemover
Removes specified components from a point cloud.
PointCloudComponentRenamer
Renames an existing component.
PointCloudComponentTypeCoercer
Alters the data type of point cloud components, and converts component values if required.
PointCloudConsumer
PointCloudCreator
Creates a point cloud of specified size and density, with default component values.
PointCloudExpressionEvaluator
Evaluates expressions on each point in a point cloud feature, including algebraic operations and conditional statements, and sets individual point cloud component values.
PointCloudExtractor
Serializes the geometry of a point cloud feature into a Blob attribute, encoding the contents according to a choice of common binary point cloud formats.
PointCloudFilter
Separates point clouds into multiple features, based on evaluating expressions including component values, and creates a separate output port for each expression defined.
PointCloudMerger
Merges point clouds by joining points where selected component values match (join key), including x, y, z, and other components. Component values are transferred between point clouds and output is filtered based on matching success and duplication.
PointCloudOnRasterComponentSetter
Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location.
PointCloudPropertyExtractor
Extracts the geometry properties of a point cloud feature and exposes them as attributes, optionally checking for their existence, retrieving component properties, and finding minimum and maximum values. Extents may also be recalculated and updated.
PointCloudReplacer
Decodes a binary attribute containing encoded point clouds stored as Blobs, replacing the feature’s geometry with the decoded point cloud.
PointCloudSimplifier
Reduces the number of points in a point cloud by selectively keeping points based on the shape of the point cloud. The simplified and removed points are output as two discrete point clouds.
PointCloudSorter
Sorts the points within a point cloud by one or more component values.
PointCloudSplitter
Separates point clouds into multiple features based on component values, color, or first/last return.
PointCloudStatisticsCalculator
Calculates statistics on point cloud components and adds the results as attributes.
PointCloudSurfaceBuilder
Takes an input point cloud and reconstructs it into an output mesh.
PointCloudThinner
Reduces the number of points in (thins) a point cloud by keeping points at a fixed interval, a maximum number of points, or a set quantity of first or last points. Remaining points are discarded.
PointCloudTransformationApplier
Applies a point cloud’s scale, offset, or transformation matrix to it, recalculating component values and removing the transformation values.
Input
Output
Point cloud features with no modifications made.
<Rejected>
General
Block Size (Points)
The point cloud will be consumed in blocks, reading this many points in each block. Adjusting this parameter is generally only useful for internal Safe testing.
How to Set Parameter Values
Text Editor
Arithmetic Editor
Dialog Options - Tables
- Add a row
- Remove a row
- Move current row up one
- Move current row down one
- Move current row to top
- Move current row to bottom
- Cut a row - delete and copy to clipboard
- Copy a row to the clipboard
- Paste a row from the clipboard
Cut, copy, and paste may be used within a transformer, or between transformers.
Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output.
Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies |
None |
Aliases |
History |
Search for all results about the PointCloudConsumer on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
