PointCloudComponentRemover
Removes specified components from a point cloud.
Jump to Configuration
  • Removing unused components
  • Removing components to meet processing or format requirements
  • Removing components to increase processing efficiency or optimize storage
The PointCloudComponentRemover receives point cloud features, removes specified components, and outputs the modified point cloud.
Standard component names may be selected from drop-down menus, whereas user-specified names must be entered directly. Multiple components may be removed.
  • The PointCloudComponentRemover and PointCloudComponentKeeper perform similar functions. The PointCloudComponentKeeper is more useful when removing a proportionately large number of components, whereas the PointCloudComponentRemover is more useful when removing a small number of components.
  • The transformer cannot detect the names or existence of any given component on the input point cloud feature. A PointCloudPropertyExtractor may be used to check for the existence of components.
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
Search for all results about the PointCloudComponentRemover on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
