CoordinateConcatenator
Retrieves the values of all the feature's coordinates into a single string attribute value, separated by delimiters.
Extracting coordinate values into attributes for manipulation or use elsewhere
The CoordinateConcatenator receives point, line, area, or donut features and extracts their coordinates into one concatenated and delimited string attribute value.
The delimiters between coordinates and between elements of a coordinate (x, y, and z) may be specified, and can be special characters such as tabs or carriage returns.
Coordinates to include (x, y, and/or z) may be selected. If z is requested on features without z coordinates, it will be ignored.
Aggregates are not supported.
In this example, we have a shapefile of parks, and want to extract their coordinates into an attribute. Note that they are in a UTM coordinate system, with ground units in meters.
The features are routed into a CoordinateConcatenator.
In the parameters dialog, the default settings are kept. Note the delimiters - pipe (|)and comma (,).
X, Y, and Z coordinates are requested by default. Our data is 2D, so the Z will be ignored and these default settings are fine.
The output features have a new _coordinates attribute.
On closer examination of the attribute value, we see the coordinates of the polygon, separated by pipe delimiters. Note that the first and last coordinate are identical - indicating a closed area.
We can use special characters as delimiters to control formatting.
Using the previous example, in the parameters dialog, we access the Text Editor via the dropdown menu on the Coordinate Delimiter parameter.
The default pipe delimiter is replaced with a carriage return character.
The output attribute value now contains coordinates separated by line, which could be written to a text file with an AttributeFileWriter or used elsewhere.
To extract coordinates into a list attribute, use the CoordinateExtractor.
Features with point, line, area, or donut geometry.
Features with coordinates added to an attribute as specified in parameters.
Coordinate Delimiter |
Specify a character or string to be inserted between each set of coordinates. |
Coordinate Element Delimiter |
Specify a character or string to be inserted between each component (x, y, z) of a set of coordinates. |
Coordinate Element(s) to Include |
Select which elements of a coordinate - x, y, and/or z - to include. If z coordinates are requested, but the data is 2D (has x and y only), z will be ignored. |
Coordinate Attribute |
Name the attribute to store the resulting coordinate values string. |
Dialog Options - Tables
Search for all results about the CoordinateConcatenator on the FME Community.
