CoordinateSwapper
Swaps coordinate axes of the input features.
General
X with Y: Each feature's x-coordinates will be swapped with its y-coordinates.
X with Z: Each feature's x-coordinates will be swapped with its z-coordinates.
Y with Z: Each feature's y-coordinates will be swapped with its z-coordinates.
There are three common uses for this transformer:
- The transformer was originally intended to help solve the problem of Lat/Long order, where some formats expect Latitude/Longitude, and others expected Longitude/Latitude.
- The transformer can also be used to swap X or Y values with the Z axis to produce a cross-section view of a dataset, such as a building model elevation.
- The transformer can also be used as a tool for quality assurance purposes, where switching the data into a different plane causes spikes in the other axes, like this:
Dialog Options - Tables
Keywords: transform transpose transposer switch
