Tester
Evaluates one or more tests on a feature, and routes the feature
according to the outcome of the test(s).
Jump to Configuration
- Performing quality testing on data
- Dividing features into two streams based on a test
- Isolating a subset of features based on a test
The Tester accepts any feature. It evaluates each feature against one or more user-defined tests, and outputs the feature via the Passed port if it meets the defined conditions, or via the Failed port if it fails the defined conditions.
The tests are constructed as a series of Test Clauses, which evaluate values or expressions based on a wide range of available Operators and test types. The Test Clauses are connected with Logic - combinations of AND, OR, and NOT, with parentheses to define evaluation order.
Creating Test Clauses
Each clause is composed of a value to test, and the method of testing it. Depending on the type of test, at a minimum the clause will consist of a Left Value and an Operator. If the chosen Operator needs more information (for example, testing for an attribute that is greater than a certain value), a Right Value field is provided.
The Test Clauses are created in a table, and numbered from the top down.
The value or expression to test
The type of test to perform
The value for comparison, if required by the operator
Test the values in a specific manner
Latitude
49.000001 |
Automatic
@Area()
In Range
(1,100)
Numeric
SnackType
Like
Kebabs
Case Sensitive
Traffic
Attribute Is Null
<Unused>
Automatic
Count
Type Is
Integer
Automatic
* Note that Mode is only available for individual tests when Comparison Mode is set to Specify Per Test.
Test Clause Operators
See all operators
These are the Operators available for constructing test clauses. They may be used to test attribute values, constructed expressions, constants, and published parameters.
Note that (unless otherwise specified) most operators can be used with both numeric values and strings. Strings may be compared with the =, !=, <, >, <=, and >= operators, and are evaluated by their character codes, so A < B.
Equal to
Enter a value for comparison. |
Not Equal to
Less than
Greater than
Less than or equal to
Greater than or equal to
In Range
Tests if the value falls within the numeric range specified in set notation.
Open-ended ranges may be defined by leaving either the lower or upper limit blank.
Range values are separated by a comma and enclosed by brackets.
Square brackets - [ ] - indicate inclusive limits (greater than or equal to, less than or equal to).
Round brackets - ( ) - indicate exclusive limits (greater than, less than).
Valid range examples:
(1,9) Greater than 1 and less than 9
[1,9] Greater than or equal to 1 and less than or equal to 9
(1,9] Greater than 1 and less than or equal to 9
(1,) Greater than 1
[,9] Less than or equal to 9
Note: This operator is not available when Mode is set to Case Sensitive or Case Insensitive, and those modes are not available when the operator is set to In Range.
In
Tests if the value may be found in the provided list of possible values and ranges. |
Enter any combination of comma-separated strings, numeric values, and/or ranges (in the form of x-y).
Valid configuration examples:
1,10,100
1-99
cat
cat,dog,cats and dogs
dogs,1-9,7
String ranges (for example, a-d) can also be specified.
To test for values that contain a hyphen, enclose the value in quotation marks:
"LL-27","LL-83".
To test for values that contain either single (') or double (") quotes, enclose the value in the opposing quotes: "Duncan's Lake" or 'Say "Hello"'.
Like
Tests that the value matches a specified string pattern.
Enter a string pattern. Wildcards are supported using the percentage symbol (%), rather than an asterisk (*).
In Automatic mode, this operator is case insensitive.
This operator is not available when Mode is set to Numeric.
Example:
If Right Value is %bc%:
abcd: Passed
bc: Failed
Contains
Tests that the Right Value occurs somewhere in the Left Value. |
Enter a value to test for.
This operator is not available in Numeric mode.
Example:
If Right Value is bc:
abcd: Passed
abde: Failed
Begins With
Tests that the Left Value string begins with the Right Value string. |
Enter the string to be tested against.
Example:
If Right Value is Do:
Dogs: Passed
Cats: Failed
Ends With
Tests that the Left Value string ends with the Right Value string. |
Example:
If Right Value is gs:
Dogs: Passed
Cats: Failed
Contains Regex
Tests that the value contains a string that matches a pattern described by a Regular Expression.
Enter a Regular Expression.
The Regular Expression Editor is available via the ellipsis (...) button, and may be used to construct and test expressions.
The regex to test may represent a string to be found anywhere within the value, or may represent the entire value (by creating a regex long enough to represent the extent of the desired value).
Example:
If regex is \d
(Any digit)
cats: Failed
9: Passed
cats82: Passed
Type Is
Tests if the value is compatible with the chosen Type.
You may test for multiple types by adding additional Test Clauses.
Select the Type to test for.
Boolean
Valid Boolean values are the strings:
- TRUE, True, true, YES, Yes, yes, 1
- FALSE, False, false, NO, No, no, 0
Double
Floating-point number
Integer
Integer
Numeric
A number (same behavior as Double)
Alphanumeric
All characters are either a digit (0-9) or a letter (a-z, A-Z).
White space, nulls, control codes, punctuation, and accented or extended characters are not included.
String
A sequence of characters. The value does not contain any null characters.
XML
Checks for valid XML syntax.
JSON
Checks for valid JSON syntax.
Encodable In
Tests if the value is encodable in the specified encoding without data loss.
Select from a list of standard encodings.
Sample encodings:
- Unicode 32-bit(utf-32)
- Windows Cyrillic (windows-12510
- EBCDIC US (ibm037)
Attribute has a value
Tests that the attribute has a value, and is not null, missing, or empty. |
<Unused>
Attribute Is Null
Tests that the attribute has a null value. |
<Unused>
Attribute is Empty String
Tests that the value is an empty string.
<Unused>
Attribute is Missing
Tests that the attribute is absent on the feature
<Unused>
Cached Values and Data-Aware Test Clauses
If Feature Caching is enabled, valid attribute values from upstream features can be viewed to complete test clauses.
As shown here in the Tester, if the Left Value has been set to an Attribute Value and the features have been cached, the context menu provides access to the values available in those features. If there are only a few choices, they will be presented in a sub-menu.
If there are a large number of choices, the values will be presented in a Select Value dialog, where the values may be sorted and searched with the Filter option.
Connecting Test Clauses: Logic
Multiple test clauses are connected with Logic, using AND, OR, and NOT in addition to parentheses to specify how the tests are evaluated to determine passing or failing.
Logic connectors can be edited by selecting options in the Logic column of the Test Clauses table, or may be edited directly using the Composite Expression parameter’s Edit button.
Example: Simple test for the existence of a value
In this example, we start with a dataset of food trucks, and want to identify any records that are missing a Business Name.
The features are routed into a Tester.
In the parameters dialog, we configure one test. The Left Value is set to the BUSINESS_NAME attribute, and the Operator is set to Attribute has a value.
As there is only one test, the Pass Criteria (AND/OR/Composite) is not relevant.
No Right Value is required, as the test is simply looking for the existence of any value.
Features that fail the test are output via the Failed port, and can be sent for further processing elsewhere.
Example: Testing for multiple choices with OR
In this example, we start with a dataset of food trucks, and wish to test for those that are serving Mexican food. The features are routed into a Tester.
In the parameters dialog, we construct two tests, both using the DESCRIPTION attribute as the Left Value.
The first test looks for an exact match - any feature where the DESCRIPTION is Mexican Cuisine. The second test is less strict - it looks for any values that begin with Tacos.
The Logic connector is set OR - meaning any feature that matches either of these tests will be output via the Passed port.
Comparison Mode is set to Case Insensitive, which will apply to both test clauses.
Four features match at least one of the tests.
Example: Composite test criteria
In this example, we start with a dataset of city parks. We will test them to find dog parks of a certain minimum size, in two specific neighborhoods. The features are routed into a Tester.
In the parameters dialog, we add four individual test clauses:
- Dog Park: Y
- Area is greater than 40000 ( square meters, in ground units - using the @Area() function to evaluate the geometry)
- Neighborhood Name is Strathcona
- Neighborhood Name is Fairview
As we have two choices of neighborhood name, we use a Composite Expression to describe the test conditions we want:
Two parks meet the criteria.
- Due to bulk mode processing, features may appear to output in chunks. Although feature order from a single output port remains intact, when chunks of features are output through both the Passed and Failed ports, unexpected results may occur in workspaces that rely on feature ordering from joined output ports. In these scenarios, we recommend that you do not upgrade the Tester to its 2019.1 or later version, or revise your workspaces so they do not rely on feature ordering from joined output ports. Feature ordering may be specified with the Advanced > Preserve Feature Order parameter.
- If you have several Tester transformers in sequence, consider using the TestFilter instead. This transformer allows you to create a series of tests with named output ports for each result.
- Note that
testing operations are lexical comparisons and not locale-aware.
- When filtering out a subset of features, consider the logic of the test(s) when choosing an output port. For example, to remove all of the Dog Parks from a list of parks, you could either:
- Set DogParks=Y, and connect the Failed port (dropping the Passed features), or
- Set DogParks=N, and connect the Passed port (dropping the Failed features).
Passed
If the feature passes according to the test configuration, it is output via the Passed port.
Failed
If the feature fails according to the test configuration, the feature is output via the Failed port.
Test Clauses
See Creating Test Clauses above for further detail.
Logic
Determines how clauses are evaluated in a composite test.
Note that changes made using the Composite Expression parameter’s Edit function will be reflected in this column once they have been Applied, including the placement of parentheses.
OR
Flexible inclusion: one of the test conditions must be met.
AND
Inclusion: the following test condition must be met.
NOT
Exclusion: the following test condition must not be met.
Parentheses
Used to construct composite expressions, specifying order of clause evaluation.
Left Value
The Left Value may be the value of an attribute, expression, a literal constant, a published parameter or a calculated value that is a combination of the above.
If it is a calculated function or expression, it will be executed for each feature and the result will be used for the test.
Operator
Select the type of test to be performed. Options include:
= (Equal to)
- != (Not equal to)
- < (Less than)
- > (Greater than)
- <= (Less than or equal to)
- >= (Greater than or equal to)
- In Range
- In
- Like
- Contains
- Begins With
- Ends With
- Contains Regex
- Type Is
- Boolean
- Double
- Integer
- Numeric
- Alphanumeric
- String
- XML
- JSON
- Encodable In
- Attribute has a value
- Attribute is Null
- Attribute is Empty String
- Attribute is Missing
Right Value
Enter any required comparison values or supplementary configuration information for the test selected.
Depending on the
Operator chosen, a drop-down list of choices or an ellipses button accessing an additional dialog with correct parameters may become available, to assist in entering values.
Mode
If required, specify a method for evaluating values.
This column is only available when Comparison Mode is set to Specify Per Test.
See Comparison Mode below for available options.
Comparison Mode
Specify a method for evaluating values.
This choice will be applied to all tests, unless Specify Per Test is selected, enabling the Mode column in the Test Clauses table.
Automatic
Compares values as numbers if possible, and strings otherwise.
Numeric
Case Sensitive
Compares values as strings using a case sensitive comparison, and will not attempt numeric conversions.
Case Insensitive
Compares values as strings using a case insensitive comparison, and will not attempt numeric conversions.
Date/Time
Compares values as FME Date/Time values if possible.
It can use different mathematical operators such as = (are the two dates the same) or > (is the first date newer than the second).
If the input data is not in FME Date format, the comparison will be done as string and an attribute, fme_expression_warnings{} will be added to the feature to indicate this was done.
Example: if Mode is set to Date/Time, “20180109141824.9024787-08:00=20180109131824.9024787-09:00” will pass the test.
Specify Per Test
Enables the Mode column, where individual comparison mode selections may be made.
- For a string that can be represented as a number such as 4.5 or 4e5, if you set Mode to Automatic or Numeric, it will be treated as a number if the comparison value is also representable as a number.
- For example, if Mode is set to Automatic or Numeric, “4E5=400000” will pass the test. If, on the other hand, you want “4E5=400000” to fail the test, set Mode to Case Sensitive or Case Insensitive.
Tip: If you know your data is string data, you should set the mode to either Case Sensitive or Case Insensitive. This way, FME does not spend time for each feature to determine if the data is representable as a number, but can just do the string comparison immediately.
Enabled when multiple test clauses are created.
Enter or edit a test expression that defines the criteria to met in order for a feature to be considered Passed. If edits are made here, the changes will be reflected in the Test Clauses table’s Logic column once the Apply button is used to save changes. Inversely, changes made by selecting Logic options will be reflected here.
Test Clauses are referred to by their number, in the order listed in the Test Clauses table. Clauses may be joined by AND, OR, and NOT, with parentheses.
Example:
((1 AND 2) OR 3)
Interpretation: Clause 1 AND Clause 2 must be true, OR Clause 3 must be true.
See the Composite example above for a use case.
When doing comparisons, null, missing, and empty string values, all evaluate to empty string. Thus, they are considered equal in the context of the comparison operators. Further, the following comparison ordering is respected:
- Null, missing, empty string < other values
In Automatic mode, all operators are case sensitive except Like, Contains, Begins With, and Ends With.
Advanced
This parameter controls the order in which features exit a transformer.
When a transformer has more than one output port, features usually exit one port at a time. At times, it may be useful to keep the order that features arrived in, switching from port to port as necessary. This allows feature order to be preserved, though at a potential cost in processing efficiency.
Select a method for feature ordering.
Per Output Port (Default)
Only preserve the input order of features as they occur within the group of features exiting a given output port.
All features exiting an output port retain their ordering relative to each other (within the group), but not relative to features exiting other output ports.
This option is generally the most efficient, where large chunks of features will exit an output port together (taking advantage of bulk mode).
As features exiting different output ports may not be strictly output in the order they arrived, output ordering may be unpredictable.
Across Output Ports
Strictly preserve the input order of features, regardless of which output port they exit. Features will be output singly in the same order they arrived, switching from port to port as necessary.
This option is generally less efficient as the processing gains of bulk mode are less likely to apply - however, feature order is predictable.
How to Set Parameter Values
Text Editor
Arithmetic Editor
Dialog Options - Tables
- Add a row
- Remove a row
- Move current row up one
- Move current row down one
- Move current row to top
- Move current row to bottom
- Cut a row - delete and copy to clipboard
- Copy a row to the clipboard
- Paste a row from the clipboard
Cut, copy, and paste may be used within a transformer, or between transformers.
Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output.
Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies |
None |
Aliases |
History |
This transformer replaced the AttributeTester and GenericTester transformers.
Search for all results about the Tester on the FME Community.
