PointCloudSplitter
- Separating a point cloud into subsets based on component values or value ranges
- Isolating points in a point cloud based on component values, value ranges, or first/last returns
The PointCloudSplitter receives point cloud features and divides them into individual point clouds, based on either unique component values or ranges of values.
The split may be performed on any numeric component, with two Split Types available:
- Unique: All unique values that exist for the selected component will be automatically identified, and one point cloud output for each value. Optionally, specific Unique Values to Keep may be chosen and only those component values will generate output features.
- Range: Ranges of values are specified, and one point cloud is output for each range. Ranges may be generated. At least one range must be specified. Any points that fall outside of all specified ranges are assigned a default value.
The transformer also has Split By First Return Only and Last Return Only options, which keep only the first and last returns, respectively, and discard all other points. Split By Color operates on ranges of RGB values.
In all cases, an Output Attribute may be added to the output features, identifying the split value.
In this example, we will divide a point cloud into parts, based on its classification component values. Note that the input point cloud does have a classification component, but we do not know what exact values may exist in the feature.
The point cloud is routed into a PointCloudSplitter.
In the parameters dialog, Split By is set to classification, and the Split Type is Unique. We keep the default Output Attribute name of _split_value.
Note that Unique Values to Keep is empty - and so all values will be output.
Five features are output, indicating the five unique values were found for classification in the input point cloud. Examining the Split output in the FME Data Inspector’s table view, we can see those values assigned to the _split_value attribute.
To examine one of these features, we further route them through an AttributeFilter, filtering on _split_value, and looking only for value 6 (buildings).
This output point cloud contains all points from the original that had a classification value of 6, indicated by its _split_value attribute.
- The PointCloudFilter provides similar functionality. It can split point clouds with more complex expressions, and provides multiple output ports, one per filter criteria. However, it does not split on automatic identification of unique values or perform simple first/last return filtering, as the PointCloudSplitter does.
One or more point cloud features as specified in the parameters.
INVALID_FEATURE_COMPONENTS
MISSING_FEATURE_COMPONENTS
Split By |
Specify the component(s) on which the point cloud will be separated. This may be any single component name, or one of the following special values:
Single components may be split using either Split Type Range or Unique. |
Split Type |
Select the type of component value specification:
Output Attribute (optional) |
The name of the attribute to be added to all output point clouds, which will identify the value that created it.
When Split Type is Range, this table specifies the ranges to produce output point clouds.
One feature will be output for each range specified, as long as at least one point falls within it. If ranges overlap, points will only be allocated to the first range they match (in table order).
Points that do not match any specified range are output as a single point cloud, with the Default Output Value assigned.
From |
The start value for the range that you are classifying. This field accepts numbers only and must be less than the corresponding To value.
To |
The end value for the range that you are classifying. This field accepts numbers only and must be greater than the corresponding From value.
Output Value |
The value assigned to the Output Attribute for each range. Values may be numbers or strings. Default: One point cloud will be output for points that do not match any range. This Default Output Value is assigned to the Output Attribute for this output feature. |
When Split Type is Unique, this table optionally specifies which values should produce output features.
Unique Values to Keep |
Optional: Enter specific values to produce output point cloud features. All non-matching points will be discarded. Limiting a splitting operation to only desired values may improve performance. If blank, all unique values will be identified and each will produce a new output feature. |
Dialog Options - Tables
Search for all results about the PointCloudSplitter on the FME Community.
Keywords: point "point cloud" cloud PointCloud LiDAR sonar
