PointCloudComponentTypeCoercer
Alters the data type of point cloud components, and converts component values if required.
- Changing component data type to meet processing or format requirements.
The PointCloudComponentTypeCoercer receives point cloud features, alters the data type of selected components, and then outputs the modified point cloud feature.
Options are available to control the manner in which values are converted, including methods for scaling values to fit a new data type and choices for rounding when converting from floating point values to integers.
Components can be converted to any of these data types:
- Real64
- Real32
- UInt64
- UInt32
- UInt16
- UInt8
- Int64
- Int32
- Int16
- Int8
- String
In this example, we will apply color to a point cloud using an orthophoto raster. The raster is RGB48 - that is, each of its color bands are 16 bits.
Note that the source point cloud feature does not have color components (colors shown in the Data Inspector are simply a representation of elevation - z coordinates).
We want to produce a point cloud with 8-bit color components, and so need two steps.
First, both the point cloud feature (LAS) and the raster feature (GEOTIFF) are routed into a PointCloudOnRasterComponentSetter, where colors will be extracted from the orthophoto and applied to the point cloud as components.
Next, the resulting point cloud feature (with 16-bit color components) is sent on to a PointCloudComponentTypeCoercer, where the data type will be changed and the color values scaled accordingly.
Step 1 - Applying Colors
In the parameters dialog of the PointCloudOnRasterComponentSetter, Components to Set is set to Color
Note that the point cloud feature produced in this first step now has color components, and they are data type UInt16 (unsigned integer, 16-bit).
When examining a single point in the point cloud, we can see that the color values fall within the range of 0 to 65535 (the possible values for a 16-bit unsigned integer).
Step 2 - Altering Data Type and Scaling Values
In the parameters dialog of the PointCloudComponentTypeCoercer, all three color components are set to Type UInt8, and the Conversion Type is set to Scale by data type. This will scale the values while preserving their proportions in regard to the original and new types’ ranges.
The output point cloud feature now has 8-bit color components.
Individual points’ color values have been proportionately scaled, and now fall within the range of 1 to 255 - the possible values for an 8-bit unsigned integer
Merges component values from one point cloud to another. Features that contain the desired components are connected through the Supplier port, and the features that will receive the components are connected through the Requestor port. |
Sorts a point cloud by the values of components. |
Applies transformations on a point cloud. Applying a transformation is primarily done for compatibility with other processing and writers that cannot support the transformation natively. For example, the LAS reader produces Int32 coordinates with a scale and offset. However, the POINTCLOUDXYZ writer cannot support component scale/offsets, so the transformation will be applied. The resulting coordinates will be Real64 with no transformation. Note that processing and writers that cannot support transformations will apply them automatically, but this transformer can be used to manually apply the transformation if desired. |
Point cloud features with component data types altered as specified in the parameters.
MISSING_FEATURE_MISSING_COMPONENTS
Each line in this table specifies a component to be altered, and parameters for doing so.
Multiple components may be modified.
Component | Select or enter the name of the component to be modified. | ||||||||||
Type | Select the desired data type of the component. | ||||||||||
Conversion Type |
Select a method for conversion. Note: Scale/Offset: Note that all conversion types except Scale by data values, preserve values are applied to the raw data values, before any transformation is applied. To convert a value in its end form (as it appears with scale and/or offset applied), use a PointCloudTransformationApplier to apply the scale/offset transformation prior to changing the component data type.
* Note: Cast and Bounded Cast use C-style casts. |
Rounding Type |
Specifies the action to perform when converting from a floating-point value to an integer.
Dialog Options - Tables
Dependencies | None |
FME Licensing Level | FME Professional Edition and above |
Aliases | PointCloudColourScaler, PointCloudColorScaler |
History |
Search for all results about the PointCloudComponentTypeCoercer on the FME Community.
Keywords: PointCloudColorScaler
