PointCloudSorter
Point cloud features with sorted points.
Specifies the components by which the point cloud will be sorted.
Points are sorted by the components in the order specified. That is, all points will be sorted by the values of the first component in the list. If there are any ties, they will be broken by the values of the second component, then the third component, etc. The list may be reordered with the Move Up and Move Down buttons.
Each component may be sorted in either ascending or descending order.
Dialog Options - Tables
FME Licensing Level
Keywords: point "point cloud" cloud PointCloud coerce LiDAR sonar
