Start FME Registration
Perform this step for each computer that has FME installed.
For command prompt instructions, see Licensing FME Desktop from the Windows Command Prompt.
- Open the FME Licensing Assistant: Start > Programs > FME Desktop > Utilities > FME Licensing Assistant.
- Select Connect to a floating license server, and enter the name of the computer that is hosting the FME licenses.
- Click the Next button.
- If your configuration contains more than one type of FME license, select the license that you want to use.
- Click Finish to complete the connection.
