You are here: Other Workbench Tasks > Working with FME Server > Publishing to FME Server > Register Services, Edit Service Properties
Register Services
This page allows you to register your workspace, custom transformer, or custom format with one or more of the FME Server Web Services.
If the web service contains configurable parameters, click the Edit... button next to the service you want to configure. For more information, see Edit Service Properties below.
Note: For more information about the FME Server Web Services, see FME Server Web Services in the FME Server documentation.
Select one or more web services and click Publish to publish the workspace to FME Server.
Note: If you uploaded any connections in the previous step (Upload Connections), click the link at the bottom of the translation log to configure web services and authorize connections in FME Server. For more information, see Upload Connections.
The properties that are available to configure in this dialog depend on which FME Server service you are editing.
