You are here: Administrator's Guide > Upgrading FME Server > Full FME Server Upgrade > Upgrading to a Second Machine, Using a Different Host Name
To Upgrade to a Second Machine, Using a Different Host Name
- Provide a new machine for the upgrade.
- Install FME Server. On the FME Server Hostname dialog, specify the new hostname.
- Backup the FME Server configuration from the old machine.
- Restore the FME Server configuration to the new machine.
- Test that your configuration has been migrated successfully.
- Uninstall FME Server from the old machine (or recycle the machine).
Hardcoded paths to the previous host name in workspaces, transformers and HTTP push subscriptions must be manually updated.
