| Home | Trees | Indices | Help |
object --+
FMEPartIterator
init()
FMEPartIterator should not be constructed directly. Instead, use the iterator semantics of FMEFeature to get an FMEPartIterator which can be used to iterate over its parts.
| a new object with type S, a subtype of T |
int
list of tuples of floats
tuple of floats
| the next value, or raise StopIteration |
int
Inherited from |
Inherited from |
x.__init__(...) initializes x; see help(type(x)) for signature
Get the part's dimension. Returns either FME_TWO_D or FME_THREE_D
Get all the part's coordinates in a list. Each coordinate is a tuple. All returned tuples have the same dimension as the part.
Get the coordinate at the specified index. The dimension of the tuple equals the dimension of the part.
| Generated by Epydoc 3.0.1 on Thu Nov 26 19:10:16 2015 | http://epydoc.sourceforge.net |
