| Home | Trees | Indices | Help |
object --+
FMELicenseManager
init()
FME License Manager class.
This class provides an interface to security functionality.
| a new object with type S, a subtype of T |
string or None
tuple of strings or None
string or None
string or None
string
string or None
string
string
string
int
int
string or None
string
string or None
string
bool
bool
bool
bool
bool
bool
bool
bool
bool
int
Inherited from |
Inherited from |
x.__init__(...) initializes x; see help(type(x)) for signature
Retrieves the value of a property from a 3rd party license file.
Returns all the factory names for the current license. For all
factories the list will be populated with
Returns all the format names for the current license. For all formats
the list will be populated with kFME_FormatRead: Only reader is licensed kFME_FormatWrite: Only writer is licensed kFME_FormatBoth: Both reader and writer are licensed kFME_FormatUnlicensed: Neither reader nor writer is licensed
Returns all the function names for the current license. For all
functions the list will be populated with
Retrieves the value of a property for a given application. This is only used for application in which there are different levels of support
Retrieves the value of a property for a given factory. This is only used for factories in which there are different levels of support
Returns the minimum base capability for the specified factory to be licensed. Will return one of the following capability names:
Retrieves the value of a property for a given function. This is only used for function in which there are different levels of support
Returns the minimum base capability for the specified function to be licensed. Will return one of the following capability names:
Retrieves the value of a property from the current license.
Returns the current license type. Possible values are MACHINE SPECIFIC, OEM, GENERIC, or FLOATING.
This routine returns the maximum number of licensed fme processes.
This routine returns the maximum number of licensed fmeworker processes.
Retrieves the value of a property for a given reader. This is only used for reader in which there are different levels of support
Returns the minimum base capability for the specified reader to be licensed. Will return one of the following capability names:
Retrieves the value of a property for a given writer. This is only used for writer in which there are different levels of support
Returns the minimum base capability for the writer factory to be licensed. Will return one of the following capability names:
Returns whether or not an application is licensed.
Returns whether or not a given ArcGIS product is installed. The following products are supported:
Returns whether or not a given factory is licensed.
Returns whether or not a given function is licensed.
Returns whether or not the Gtrans reprojection library is installed.
Returns whether or not a given reader is licensed.
Returns whether or not a given writer is licensed.
This method is used to validate a license file. Note: It is not using the license file but rather merely returning whether or not the license file is valid for the current machine if it is installed.
| Generated by Epydoc 3.0.1 on Thu Nov 26 19:10:16 2015 | http://epydoc.sourceforge.net |
