You are here: Working with FME DesktopWorking with Coordinate SystemsReverting to Original Coordinate Systems
Reverting to Detected Coordinate Systems
If you previously changed the source coordinate system, you can revert back to the original, detected coordinate system.
Delete the text in the dialog that appears, and click OK.
The coordinate system label will revert to the original coordinate system (usually <not set>).
