You are here: Working with FME DesktopWorking with Coordinate SystemsChoosing from the Coordinate System Gallery
Tools > Browse Coordinate Systems; or select More Coord Systems... in any Coordinate System field
From the Coordinate System Gallery, you can search for a keyword, filter entries, select a new coordinate system, and view properties on selected coordinate systems.
Any custom coordinate systems that you add will also appear here. See About Custom Coordinate Systems
