Open topic with navigation
Troubleshooting Active Directory Configurations
Tips before starting:
- Start with the configuration in Configuring FME Server with Active Directory.
- Ensure that SECURITY_DEBUG=true is set in the fmeServerConfig.txt. This configuration parameter is located under the 'Security Management' heading. With this debugging flag enabled, all interactions with Active Directory are logged.
- Look in the fmeServer_* log files for messages with '(Active Directory)' or '(Single Sign-On)'. These files are located in <FMEServerDir>/Logs.
In this section:
