The Create Workspace dialog (File > New) contains a list of available templates, either stored locally or downloadable from the FME Store:
When you create templates from existing workspaces, the template categories are added to this list. Click a category to see the workspaces
Some templates are included with each FME Desktop installation. These will be shown here, along with any templates that you download and install from the FME Store for use with both FME Desktop and FME Server. Downloadable templates are updated frequently.
These templates are downloadable from the FME Store. The FME Store contains templates and custom transformers that are described as part of solutions on FMEpedia.safe.com, as well as workspace elements created by third parties.
Requesting catalog details for selected template... Retrieved catalog details. Connecting to FME Store... Successfully connected. Downloading '<template_name>.fmwt.fmwt'...Successfully downloaded file. Successfully downloaded '<template_name>.fmwt' from FME Server to '<default_location>\FME\FME Store\Templates\LAS_PDF_3D.fmwt'. Disconnecting... Successfully disconnected.
Note that if you have an open workspace, you will be prompted to save and close the workspace.
