Templates allow you to create a workspace using a predesigned format and structure. They are one of the best ways to get started with FME Workbench, whether you're new to FME, whether you're setting up a new workflow and you want some hints to get started, or even if you want to implement some best practices in your workspaces.
FME templates can include source datasets within the file. Both a workspace example and the data required to run the workspace can be bundled together.
Templates have the file extension .fmwt.
There are several advantages to using templates in Workbench:
Saving a Workspace as a Template
Creating Workspaces from Templates
