Open topic with navigation
Network
Select Tools > FME Options and
click the Network icon.
Your organization may require you to use a proxy before you can use FME. Proxies are often part of corporate firewalls.
You can also use this setting to specify a proxy server for FME Server. See Connecting to FME Server.
Proxy Options
- No proxy: Choose this if you don't want to use a proxy. This is the default setting.
- Use system proxy settings: Choose this if you want to use the proxy settings configured for your operating system (Control Panel > Internet Options > Connections > LAN Settings).
- Proxy server requires authentication: If your proxy server requires login access, can enter it here. (Ask your system administrator for configuration information).
