Open topic with navigation
Using the Workspace Wizard
Location in FME Workbench:
File > New > Generate workspace using wizard...
If you start Workbench without using shortcuts
with any pre-existing data or workspace files, following the steps in
the wizard is the easiest way to create a new workspace file:
- Select
the source format from the pull-down list. See Choosing from the Formats List.
- Click the browse button to locate
your source data. Click the Advanced Browser button to add multiple source datasets.
- Specify
format parameters. If
the Parameters button is enabled (and this depends on the format you choose),
you can specify more detailed information about the source data. These are optional parameters so if you do not edit them, Workbench will use default settings. Click the Help button in a parameter box for information on parameter fields.
- Select
your destination format, either from predefined formats in the pull-down
list, or from the .
- Click
Finish to create the workspace.
Once you have created the initial workspace
and it is displayed in the graphical view, you can either save the file
in its current form, or adjust the data flows by adding
transformers or new
attributes.
