Tools > Browse Readers and Writers
The Reader and Writer Gallery lists all formats supported by FME.
It includes the following information:
| Column | Definition |
| Description | Full format name |
| Short Name | Common abbreviation for the format |
| Extensions | Lists file extension(s) associated with the format |
| Type | Indicates whether the format is a file- or directory-based format |
| Read/Write | Indicates whether the format is a reader, a writer, or both |
| Coordinate System | Indicates whether a custom coordinate system is associated with the format |
| Licensed | Some formats require that you obtain special licensing, or specific versions of FME. This column indicates whether your FME is licensed to read/write the format |
| Search | Enter a keyword or a partial text string to filter results. |
| Custom Formats |
| Close | Close the gallery. |
| Details | Click on a format, then click Details to display the technical documentation for the format. |
