FME Transformers: 2025.2 BETA
Categories
Data Quality
GeometryValidator
Detects selected issues in input features, and optionally repairs detected issues.
Each input feature is processed individually.
Issue Detection and Repair
For more information about the issues that are detected and/or repaired, see GeometryValidator Issues Table.
Issue detection only occurs within geometries, including geometric properties such as text rotation and arc sweep angle. That means attributes, traits, geometry labels, and other non-geometric properties are not processed.
Features with a geometry unsuited to a test (like line features in a test for area orientation) count as a pass and no repair is attempted.
In general, input geometry types are preserved unless they cannot be.
For example, an arc that degenerates into a point cannot remain an arc and at the same time be non-degenerate. So, when the issue Degenerate and Corrupt Geometries is selected, and Attempt Repair is set to Yes, the arc should be repaired into a point.
As another example, a donut that contains a non-degenerate outer shell, a degenerate hole, and a non-degenerate hole can remain a donut after degeneracy repair. The donut simply drops the degenerate hole, and remains a donut.
If a geometry is split into multiple pieces as a result of repair, those pieces will be grouped into an appropriate composite or multi geometry. If the original geometry was itself a part of a collection, that collection may be changed to an aggregate as a result.
If an input geometry contains multiple issues, but only a subset of them is being detected and repaired, expect undefined behavior. For example, if an arc containing a NaN (Not a Number) is being repaired only for degeneracy and corruption, the number of NaNs in that arc could increase. As another example, if you attempt to repair self-intersections in a degenerate geometry, it may come out with a different geometry type and lose its coordinates.
In general, the detection and repair of some issues depends on the absence of other issues. Further, during the repair of a particular issue, other issues may be created. If input issue dependencies are respected, it should be expected that the output of an issue repair operation should no longer contain that issue.
Input Dependencies for Issues
The detection and repair of the following issues depends on the absence of other issues:
Degenerate or Corrupt Geometries
no NaNs or infinities in input
Self-Intersections in 2D
no NaNs, infinities, degeneracies, or corruptions in input
Tip  To avoid undefined behavior, select Degenerate or Corrupt Geometries and Contains NaN (Not a Number) or Infinity before selecting Self-Intersections in 2D.
Non-Planar Surfaces
Invalid Solid Boundaries or Invalid Solid Voids
no NaNs or infinities, duplicate consecutive coordinates, degeneracies or corruptions, or self-intersections within individual faces in input
Invalid Solid Voids
no invalid solid boundaries
Output Dependencies for Issues, Assuming Input Dependencies Respected
Repairing the following issues can produce other issues:
Contains -0, NaN, or Infinity
can produce degenerate output
can produce self-intersecting output
Contains Null Geometry Parts
Duplicate Consecutive Points
can produce degenerate faces in the boundary
The recommended ordering of issues to detect is built into the Issue column. If a different ordering is desired, highlight an issue, then click the up and down arrows on the bottom of the issues table.
Tip  Different orderings of issues to detect and repair may cause output geometries to change.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases GeometryOGCValidator DuplicateCoordinateRemover SelfIntersector
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the GeometryValidator on the FME Community.
