FME Transformers: 2025.2 BETA
GeometryValidator Issues Table
Here is a listing of the possible information reported for each issue in the GeometryValidator issues table. If an attribute or trait name can have several values, the values are listed next to the same attribute or trait name.
Not every attribute or trait presented will be reported for every occurrence of an issue. For example, a table may contain a Not Fully Repaired entry for repair state:
_issues{0}.repair_state Not Fully Repaired
If the geometry is fully repaired, a repair_state entry will not be present.
When issues arise on meshes, supplementary_info may contain information about which part of the original mesh had the issue:
_issues{0}.supplementary_info{0}.details Miscellaneous
_issues{0}.supplementary_info{0}.location.x 1
_issues{0}.supplementary_info{0}.location.y 0
_issues{0}.supplementary_info{0}.location.z 0
_issues{0}.supplementary_info{0}.original_part_index 0
_issues{0}.supplementary_info{1}.original_part_index 1
Since this information is unique to meshes, it is presented at the top of this document, but is otherwise not presented in any of the tables below.
Contains -0, NaN, or Infinity
Attributes
_issues{0}.count 1
_issues{0}.issue_found Contains NaNs or Infinities
_issues{0}.supplementary_info{0}.count 1
Traits
_issues{0}.count 1
_issues{0}.supplementary_info Some part(s) will be removed on repair
Contains Null Geometry Parts
Attributes
_issues{0}.count 1
_issues{0}.issue_found Contains Null Geometry Parts
Traits
_issues{0}.count 2
Duplicate Consecutive Points
Attributes
_issues{0}.count 9
Duplicate Consecutive Points in 2D
Duplicate Consecutive Points in 3D
_issues{0}.location_sample.x 0
_issues{0}.location_sample.y 15
_issues{0}.location_sample.z 1
_issues{0}.supplementary_info{0}.count 9
_issues{0}.supplementary_info{0}.location_sample.x 0
_issues{0}.supplementary_info{0}.location_sample.y 15
_issues{0}.supplementary_info{0}.location_sample.z 1
Traits
Note that .count is a count of the total number of identical, consecutive coordinates. The minimum reported .count value is therefore 2.
_issues{0}.count 9
_issues{0}.supplementary_info{0}.count 2
_issues{0}.supplementary_info{0}.location.x 0
_issues{0}.supplementary_info{0}.location.y 15
_issues{0}.supplementary_info{0}.location.z 1
_issues{0}.supplementary_info{1}.count 3
_issues{0}.supplementary_info{1}.details Miscellaneous
_issues{0}.supplementary_info{1}.location.x 5
_issues{0}.supplementary_info{1}.location.y 5
_issues{0}.supplementary_info{1}.location.z 5
_issues{0}.supplementary_info{2}.count 2
_issues{0}.supplementary_info{2}.details Miscellaneous
_issues{0}.supplementary_info{2}.location.x 1
_issues{0}.supplementary_info{2}.location.y 2
_issues{0}.supplementary_info{2}.location.z 2
_issues{0}.supplementary_info{3}.count 2
_issues{0}.supplementary_info{3}.details Miscellaneous
_issues{0}.supplementary_info{3}.location.x 0
_issues{0}.supplementary_info{3}.location.y 15
_issues{0}.supplementary_info{3}.location.z 1
Degenerate or Corrupt Geometries
Attributes
_issues{0}.count 1
_issues{0}.issue_found Degenerate or Corrupt Geometries
_issues{0}.location_sample.z 15
_issues{0}.supplementary_info{0}.details Explicit end point locations are too far from the parameter-defined arc.
_issues{0}.supplementary_info{0}.location.z 15
Traits
_issues{0}.count 1
  • Some part(s) will be removed on repair.
  • Container geometry has no parts.
  • Explicit end point locations are too far from the parameter-defined arc.
  • Area boundary is not closed.
  • Miscellaneous
Self-Intersections in 2D
Attributes for Self-Intersected Geometries
_issues{0}.count 1
_issues{0}.issue_found Self-Intersections in 2D
Attributes for Remnants
_issues{0}.count 1
_issues{0}.repair_state Remnant
Traits for Self-Intersected Geometries
_issues{0}.count 4
  • MultiPoint: Overlapping points
  • MultiCurve: Intersecting Curves
  • MultiArea: Overlapping Areas
  • MultiArea: Areas sharing an edge
_issues{0}.supplementary_info{1}.location.z 2
_issues{0}.supplementary_info{2}.location.z 1
_issues{0}.supplementary_info{3}.location.z 0
Traits for Remnants
_issues{0}.count 1
_issues{0}.supplementary_info{0} Miscellaneous
Contains Non-Planar Surfaces
Attributes
_issues{0}.count 1
_issues{0}.issue_found Non-Planar Surfaces
_issues{0}.supplementary_info{0}.details Thickness exceeds tolerance
Traits
_issues{0}.count 1
_issues{0}.supplementary_info{0} Triangulated normal angles exceed tolerance
Invalid Solid Boundaries
Attributes
_issues{0}.count 1
_issues{0}.issue_found Invalid Solid Boundaries
_issues{0}.issue_found.supplementary_info{0}.count 1
_issues{0}.issue_found.supplementary_info{0}.details Dangling faces
Traits
  • Vertices Not Used
  • Not Enough Faces
  • Face Wrong Orientation
  • Not a Valid 2-Manifold
  • Surface Self Intersects
  • Surface Not Closed
  • Surface Wrong Orientation
  • Multiple Connected Components
  • Vertices Not Used
  • Not Enough Faces
  • Miscellaneous
Invalid Solid Voids
Attributes
_issues{0}.count 1
_issues{0}.issue_found Invalid Solid Voids
_issues{0}.supplementary_info{0}.details Invalid Solid Boundaries
Traits
_issues{0}.count 1
  • Duplicate Shells
  • Shells Intersect
  • Inner Shell Outside Outer
  • Interior of Shell Not Connected
  • Invalid Solid Boundaries
  • Duplicate Shells
  • Shells Intersect
  • Miscellaneous
Spatial Standard Compliance
Attributes
_issues{0}.count 1
_issues{0}.issue_found Not Spatial Standard Compliant
  • Self-Intersection
  • Hole Outside Shell
  • Nested Holes
  • Disconnected Interior
  • Nested Shells
  • Duplicated Rings
  • Too Few Points
  • Invalid Coordinate
  • Repeated Point
  • Inconsistent Orientation
  • Unsupported Type
  • Non-Planar
  • Disconnected Surface
  • Invalid Solid
  • Undetermined Error
_issues{0}.supplementary_info{0}.details Inconsistent Orientation
Traits
  • Self-Intersection
  • Nested Holes
  • Nested Shells
  • Duplicated Rings
  • Too Few Points
  • Repeated Point
  • Unsupported Type
  • Non-Planar
  • Invalid Solid
  • Self-Intersection
  • Nested Holes
  • Nested Shells
  • Duplicated Rings
  • Too Few Points
  • Repeated Point
  • Unsupported Type
  • Non-Planar
  • Invalid Solid
Mismatched Dimensions
Attributes
_issues{0}.count 1
_issues{0}.issue_found Mismatched Dimensions
Traits
_issues{0}.count 1
Missing Measures and Elevations
Attributes
_issues{0}.count 3
_issues{0}.issue_found Missing Measures and Elevations
_issues{0}.location_sample.z 0
_issues{0}.supplementary_info{0}.location_sample.z 0
Traits
_issues{0}.supplementary_info{1}.location.x 1
_issues{0}.supplementary_info{1}.location.y 13
_issues{0}.supplementary_info{1}.location.z 0
_issues{0}.supplementary_info{2}.location.x 2
_issues{0}.supplementary_info{2}.location.y 12
_issues{0}.supplementary_info{2}.location.z 3
Missing Texture Coordinates
Attributes
_issues{0}.count 3
_issues{0}.issue_found Missing Texture Coordinates
_issues{0}.count 3
Traits
Missing Vertex Normals
Attributes
_issues{0}.count 1
_issues{0}.issue_found Missing Vertex Normals
Traits
_issues{0}.count 1
_issues{0}.location.x 0
_issues{0}.location.y 15
_issues{0}.location.z 0
Area Orientation
Attributes
_issues{0}.count 1
_issues{0}.issue_found Incorrect Orientation
Traits
_issues{0}.count 1
Solid Orientation
Attributes
_issues{0}.count 1
_issues{0}.issue_found Incorrect Solid Orientation
Traits
_issues{0}.count 1
Surface Orientation
Attributes
_issues{0}.count 1
_issues{0}.issue_found Incorrect Surface Orientation
Traits
_issues{0}.count 1
