FME Transformers: 2025.2 BETA
Categories
Cartography and Reports
DocumentPDFStyler
Prepares features for output to the DocumentPDF Writer by applying styling with PDF format-specific attributes.
Jump to Configuration
  • Styling PDF output
The DocumentPDFStyler receives features and applies various styles to them for output via the DocumentPDF Writer.
Styles are available for:
  • Column Layout
  • Heading
  • Image
  • List
  • Page Break
  • Page Properties
  • Paragraph
  • Table
  • Table of Contents
  • Title
Markdown Styling and Links
Markdown can be used to apply additional styling or create links when the input is text, with the exception of Title.
Inline Styling
Syntax and Example
Description
**bold**
Use double asterisks to bold text.
__italic__
Use double underscores to italicize text.
--underline--
Use double hyphens to underline text.
~~strikethrough~~
Use double tildes to strikethrough text.
\**bold\**
Use backslashes (\) to escape a character sequence (for example, if it would be incorrectly interpreted as a formatting marker).
Links
Link Type
Syntax
Example
External URL
[link text](URL)
Provide the text to display and the URL.
Adding a URL without markdown syntax creates a clickable link; however, since the link text will not be colored blue or underlined, using markdown syntax is always recommended.
[Google](https://google.com)
Google
Page in document
[link text](page number)
Provide the text to display and the page number.
[Page 3](3)
Page 3
Heading in document
[link text](#heading)
Provide the text to display and the heading.
The heading is case-sensitive and must contain all the characters of the heading, including spaces.
[Introduction](#Introduction)
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the DocumentPDFStyler on the FME Community.
