DocumentPDF Format Attributes
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Type Attributes), this format also adds format-specific attributes (Format Attributes).
See below for information about Markdown Syntax and Font Usage.
Attribute Name |
Contents |
documentpdf_borders_layout |
Sets the visible table borders. Values: All NONE INTERNAL MINIMAL HORIZONTAL_LINES NO_HORIZONTAL_LINES SINGLE_TOP_LINE |
documentpdf_column_layout_count |
Adds the element to a multi-column layout, grouping it with other elements that have the same attribute value. This attribute specifies the total number of columns in the layout. Elements are placed into columns from left to right. Once a column is full, placement continues in the next column. When all columns on a page are full, the layout continues on a new page. |
documentpdf_footer_center |
Sets text for the center of the footer. |
documentpdf_footer_left |
Sets text for the left side of the footer. |
documentpdf_footer_right |
Sets text for the right side of the footer. |
documentpdf_heading_level |
Sets the heading level for the text. Values: 1 2 3 4 |
documentpdf_header_center |
Sets text for the center of the header. |
documentpdf_header_left |
Sets text for the left side of the header. |
documentpdf_header_right |
Sets text for the right side of the header. |
documentpdf_image_caption_position |
Sets the position of the image caption. Values: top bottom |
documentpdf_image_compression |
Specifies the compression filter used for the image within the PDF. Values:
documentpdf_image_link |
Makes the image a clickable link to the provided destination.
documentpdf_image_filename |
Specifies the path and filename of the image. If not provided, DocumentPDF will use the feature’s geometry as the image source. Officially supported formats:
documentpdf_image_rotation |
Specifies a rotation for the image in degrees. The image is rotated counterclockwise. If a caption is set, it will not be rotated with the image. Note Due to inherent limitations in the PDF format, hyperlink boundaries cannot be rotated with the image. So, if there is a hyperlink on the image and the rotation degree is not a multiple of 90°, the clickable boundary will remain fixed to the original image dimensions.
documentpdf_image_width |
Specifies the width of the image. The height will scale to retain the same aspect ratio. If blank, use the image’s native width. |
documentpdf_image_width_unit |
Specifies the unit of documentpdf_image_width. Values:
documentpdf_list_item_indent_level |
Specifies the indent level of the list item. |
documentpdf_list_item_order |
Indicates whether the list item is ordered with numbers or unordered with bullets. Values:
documentpdf_outer_border_width |
Sets table outer border width if outer border is visible. |
Sets the orientation of all following pages. This attribute will be ignored when using a custom page size. Values:
Sets the page size of all following pages. Values:
documentpdf_page_size_unit |
Set the unit of the specified width and height. If documentpdf_page_size is a custom size, this is required. Values:
documentpdf_table_row_headings |
Attribute list containing the text to appear in the first row of the table as column headings. To be part of the same table, every table_row must have the same documentpdf_table_row_headings attribute. |
documentpdf_table_row_values |
Attribute list containing the text to appear in a row of the table. |
documentpdf_table_row_widths |
Attribute list containing the widths of each column in percent of page width. If set to stretch, the column will split the remaining page width among all stretch columns. Only the first table_row’s widths will be used. |
documentpdf_text |
Sets the text for the element. |
documentpdf_type |
Sets the type of the element. Values: heading
list_item
page_break
page_properties
paragraph
table_row
table_of_contents
title
Formatting Attributes
Formatting Attributes allow styling aspects of each element. Some elements support more than one group of formatting attributes. These are distinguished by the suffix text, heading, table, or image.
Attribute Name |
Contents
documentpdf_align_{text, heading, table, image} |
Specifies the text alignment. Values: LEFT CENTER RIGHT JUSTIFY Note for Tables: The first table row’s “text” alignment sets alignment for the entire table. Note for List Items: CENTER and RIGHT default to LEFT. |
documentpdf_font_color_{text, heading} |
The color of the text. Overrides fme_color. Three comma-separated numbers from 0 to 1 for red, green, and blue. Example: 1,0.5,0.125 |
documentpdf_font_emphasis_{text, heading} |
Sets the emphasis of the font ( bold, italic, underline, and strikethrough). String containing any combination of “BIUS”. Example: BUS |
documentpdf_font_family_{text, heading} |
The name of the font to use for the text. Will search the system for fonts to embed in the PDF. |
documentpdf_font_fill_color_{text, heading} |
The background color of the text. Overrides fme_fill_color. Three comma-separated numbers from 0 to 1 for red, green, and blue. Example: 1,0.5,0.125 |
documentpdf_font_line_spacing_{text, heading} |
Defines the spacing between lines of text. Multiplier. 1 has no effect. Note for Tables: The first table row’s “text” line spacing sets line spacing for the entire table. |
documentpdf_font_size_{text, heading} |
The size of the font, in points. Note for Tables: The first table row’s “text” font size sets the font size for the entire table. |
documentpdf_opacity_{watermark} |
A number from 0.0 to 1.0 specifying opacity. A value of 0 is completely transparent. |
documentpdf_padding_bottom_{text, heading, table, image, list} |
The amount of padding at the bottom of the element, in points. |
documentpdf_padding_left_{text, heading} |
The amount of padding at the left of the element, in points. Only supported for tables. |
documentpdf_padding_right_{text, heading} |
The amount of padding at the right of the element, in points. Only supported for tables. |
documentpdf_padding_top_{text, heading, table, image, list} |
The amount of padding at the top of the element, in points. |
fme_color |
The color of the text. Overridden by documentpdf_font_color_{text, heading}. Three comma separated numbers from 0 to 1 for red, green, and blue. Example: “1,0.5,0.125” |
fme_fill_color |
The background color of the text. Overridden by documentpdf_font_fill_color_{text, heading}. Three comma-separated numbers from 0 to 1 for red, green, and blue. Example: 1,0.5,0.125 |
Markdown
Text input supports the following markdown syntax for inline formatting and linking.
Syntax and Example |
Description |
**bold** |
Use double asterisks to bold text. |
__italic__ |
Use double underscores to italicize text. |
--underline-- |
Use double hyphens to underline text. |
~~strikethrough~~ |
Use double tildes to strikethrough text. |
\**bold\** |
Use backslashes (\) to escape a character sequence (for example, if it would be incorrectly interpreted as a formatting marker). |
Markdown Links
Link to external URL |
[link](https://google.com) Adding a plain URL without markdown syntax still creates a clickable link; however, since the link text will not be colored blue or underlined, using markdown syntax is always recommended. |
Link to page |
[link](3) links to page 3 |
Link to heading |
[link](#Heading Text) links to the heading with text “Heading Text” The link is case-sensitive and must contain all the characters of the heading, including spaces. |
Ensure Consistent Font Usage Across Systems
When generating PDFs, different systems may have different sets of installed fonts. As a result, a workspace that produces a document with one set of fonts on a local machine may produce a different-looking document when run on another system, such as when the workspace is published to FME Flow.
To avoid inconsistencies and ensure that documents render exactly the same across all environments, you can configure DocumentPDF to load fonts from a specific folder instead of relying on system-installed fonts.
This is achieved by setting the documentpdf_custom_font_dir attribute.
Value: A path to a folder containing the required font files.
Specifies the folder path from which DocumentPDF will load fonts.
When set, DocumentPDF will search only the specified folder for font files – it will no longer search the system font folders. This guarantees that the same fonts are used consistently across all systems where the workspace is run.
