FME Transformers: 2025.2 BETA
Categories
Calculated Values
Coordinates
Related Transformers
DecimalDegreesCalculator
DMSCalculator
Calculates degrees, minutes, and seconds (DMS) from a decimal degrees value provided as an attribute.
Jump to Configuration
  • Calculating the DMS (degrees, minutes, seconds) equivalent of latitude and longitude decimal degree values.
The DMSCalculator receives any feature with an attribute containing a valid decimal degree value, and converts that value to degrees, minutes, and seconds. The results are added as attributes to the output feature.
If an invalid (for example, non-numeric) value is received, the translation will fail.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the DMSCalculator on the FME Community.
