FME Transformers: 2025.2 BETA
Categories
Calculated Values
Coordinates
Related Transformers
DMSCalculator
DecimalDegreesCalculator
Calculates a decimal degree value from separate degrees, minutes, and seconds (DMS) values, provided as attributes.
Jump to Configuration
  • Calculating the decimal degree equivalent of latitude and longitude DMS (degrees, minutes, seconds) values.
The DecimalDegreesCalculator receives any feature with attributes containing valid degrees, minutes, and seconds values, and converts those to decimal degrees. The result is added to the output feature as an attribute.
If an invalid (for example, non-numeric) value is received, the translation will fail.
  • If degrees, minutes, and seconds are concatenated into a single string, they can be extracted with a StringSearcher or AttributeManager with string functions.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the DecimalDegreesCalculator on the FME Community.
