CoordinateSystemDescriptionConverter
Converts coordinate systems between FME and AutoDesk WKT, EPSG, Esri WKT, MapInfo, OGC WKT, Oracle SRID, and PROJ.4 representations.
If, for example, you are converting from Esri Shapefile to Oracle Spatial, in addition to converting the data, FME also converts the coordinate system metadata from the Esri representation to the Oracle representation. This transformer allows you to do this manually.
The attribute that contains the source coordinate system.
- Convert from FME Representation: Set the Representation parameter to the coordinate system type that you want to use to format the output field.
- Convert to FME Representation: Set the Representation parameter to select the coordinate system format to use when interpreting the input field.
- Autodesk Well Known Text (WKT)
- EPSG number
- Esri Well Known Text (WKT)
- MapInfo String
- OGC Well Known Text (WKT)
- Oracle SRID number
- PROJ.4 string
This is the attribute that will contain the results. The default name is _newcoordsys.
You should use this transformer only in rare instances, much like the Reprojector. Instead, you should use the workspace Navigator view to set the source and destination coordinate systems for the translation.
This transformer can be used in conjunction with the CoordinateSystemFetcher and CoordinateSystemSetter to use externally defined coordinate systems with FME features within the transformation environment.
Dialog Options - Tables
