CoordinateSystemSetter
Tags all features with the specified coordinate system. It does not reproject features, or otherwise modify their geometry.
You should use this transformer if you know the feature belongs to a certain coordinate system, but it is not tagged. This can happen if the feature is read from a format that does not store coordinate system information.
Specify a coordinate system.
- To reproject features, either change the source and destination coordinate systems in the Navigator, or use the Reprojector transformer.
- To remove the coordinate system from features, use the CoordinateSystemRemover transformer.
Setting a Feature’s Coordinate System Based on an Attribute Value
The following example shows how to set a feature’s coordinate system based on an attribute value.
Input features should have this attribute set to the FME coordinate system name as shown in the Coordinate System Gallery (the example below uses "CH13"). This example provides input features with their "cs_attr" attributes set to "CH-13".
Click the Properties button in the CoordinateSystemSetter transformer. Click the down arrow beside Coordinate System and select AttributeValue > cs_attr.
Dialog Options - Tables
