| Database Connection Create | Database Connection was created. |
        | Key | Description |
        | databaseConnection.event | Database Connection action: Add |
        | databaseConnection.name | Database Connection name |
        | databaseConnection.type | Database Connection type |
        | event.id | Event ID |
        | source | Event type |
        | systemEvent.description | System Event description |
        | systemEvent.title | System Event title |
        | time | Event time |
        | user | Performed by |  |
                                                            | Database Connection Delete | Database Connection was deleted. |
        | Key | Description |
        | databaseConnection.event | Database Connection action: Remove |
        | time | Event time |
                                                            | Database Connection Update | Database Connection was updated. |
        | Key | Description |
        | databaseConnection.event | Database Connection action: Update |
        | time | Event time |
                                                            | Error Logs | Error was recorded in fmeserver.log file. |
        | Key | Description |
        | message | Message content |
        | time | Event time |  |
                                                            | Failed Login | Failed login on the Web User Interface. |
        | Key | Description |
        | time | Event time |
                                                            | FME Server Startup | The FME Server Core, FME Notifier, FME Relayer, and FME Server Job Queue processes are started, healthy, and running. This event means FME Server is ready to run jobs. |
        | Key | Description |
                                                            | License Expiry | FME Server license is expiring soon. |
        | Key | Description |
                                                            | Project Export | Project was exported. |
        | Key | Description |
        | migration.id | Task ID |
        | migration.options | Migration options |
        | migration.status | Status |
        | time | Event time |
                                                            | Project Import | Project was imported. |
        | Key | Description |
        | time | Event time |
                                                            | Repository Create | Repository was created. |
        | Key | Description |
        | repository.event | Repository action: Add |
        | repository.path | Repository/Item name |
        | time | Event time |
                                                            | Repository Delete | Repository was deleted. |
        | Key | Description |
        | repository.event | Repository action: Remove |
        | time | Event time |
                                                            | Repository Item Create | Repository item was created. |
        | Key | Description |
        | repository.event | Repository action: Publish |
        | time | Event time |
                                                            | Repository Item Delete | Repository item was deleted. |
        | Key | Description |
        | time | Event time |
                                                            | Repository Item Download | Repository item was downloaded. |
        | Key | Description |
        | repository.event | Repository action: Download |
        | time | Event time |
                                                            | Repository Item Update | Repository item was updated. |
        | Key | Description |
        | time | Event time |
                                                            | Repository Update | Repository was updated. |
        | Key | Description |
        | time | Event time |
                                                            | Successful Login | Successful login on the Web User Interface. |
        | Key | Description |
        | time | Event time |
                                                            | System Backup | FME Server configuration was backed up. |
        | Key | Description |
        | time | Event time |
                                                            | System Restore | FME Server configuration was restored. |
        | Key | Description |
        | time | Event time |
                                                            | User Create | User account was created. |
        | Key | Description |
        | account.email | User email |
        | account.enabled | User enabled |
        | account.event | User action: Add |
        | account.fullName | User full name |
        | account.name | User name |
        | account.roles | User roles |
        | acccount.sharingEnabled | User sharing enabled |
        | time | Event time |
                                                            | User Delete | User account was deleted. |
        | Key | Description |
        | account.event | User action: Remove |
        | time | Event time |
                                                            | User Update | User account was updated. |
        | Key | Description |
        | account.event | User action: Update |
        | time | Event time |
                                                            | Warning Logs | Warning was recorded in fmeserver.log file. |
        | Key | Description |
