System Email
Select System Configuration > General.
Configure settings for the SMTP email server to use when FME Server sends e-mails about System Events and Reset Password. Configure the fields under Email Settings. When finished, click Save.
Email Settings
Tip: To auto-populate some fields for common SMTP servers, click Load Template.
SMTP Server: Mail exchange server domain name or IP address used for sending email.
 Common SMTP Server Domain Names
                                            | Provider | Server |
| Gmail | smtp.gmail.com |
| Outlook | smtp.live.com |
| Office 365 | smtp.office365.com |
| Yahoo Mail | smtp.mail.yahoo.com |
| Mail.com | smtp.mail.com |
| AOL Mail | smtp.aol.com |
| Zoho Mail | smtp.zoho.com |
| Yandex | smtp.yandex.com |
SMTP Server Port: Mail exchange TCP port used for sending email. If Connection Security (below) is SSL/TLS, specify port 465. If StartTLS or None, specify port 587.
SMTP Account: If the SMTP server requires authentication, this is the user name.
SMTP Password: If the SMTP server requires authentication, this is the user password.
Connection Security - The encryption mechanism used for the connection.
- SSL/TLS: The connection uses Transport Layer Security (TLS), formerly Secure Sockets Layer (SSL), supported by most common SMTP e-mail servers.
- StartTLS: An SSL/TLS connection with the e-mail server is initiated using the STARTTLS command.
- None: The connection is unencrypted.
Email From: Corresponds to the "From" field in standard e-mail messages. If users reply to the notification e-mail, it is directed to this address.
