Creates a buffer zone of specified size around or inside input geometry.
The Bufferer accepts 2D point, curve (line), and area geometries when the Buffer Type is Area (2D). All geometry types are accepted when the Buffer Type is Solid.
Point and lines may be expanded, creating surrounding polygons or solids with points offset by the specified Buffer Distance in the specified units. Areas may be expanded or shrunk, using positive or negative Buffer Distances, but solids require positive Buffer Distances.
The attributes of the original features are retained, and the buffer is output, discarding the original geometry.
A selection of end cap and corner styles is available.
An optional list attribute may be created, holding multiple attributes for grouped or aggregate input.
In this example, we buffer arterial streets (shown in blue) to find address points that fall within a fixed distance of them.
The arteries are routed into a Bufferer.
We enter a Buffer Distance of 50 and Buffer Distance Units of Meters, representing 50 meters, as our data is in a UTM projection with ground units in meters.
The buffered streets are then sent to a SpatialFilter, along with the address points, and are tested for points that fall within the buffers.
In this example, we take a point dataset of food carts that has an attribute containing the average number of daily customers they serve. We route the points into the Bufferer.
A bit of experimentation shows that dividing the daily traffic numbers by 10 will produce a desirable range of bubble sizes, and so we set the Buffer Distance to the value of the DAILY_TRAF attribute, divided by 10.
The resulting buffers are colored according to the category of food cart (type of food served).
If the Buffer Type parameter is Area (2D), then only 2D geometries are accepted as input.
If the Buffer Type parameter is Solid, then all geometry types are accepted as input.
Each point on the boundary of the output area or solid will be the specified amount away from the input geometry.
The original geometry is not output.
Features with invalid geometries are output through this port along with an additional attribute, fme_rejection_code, to indicate the reason for rejection.
If the Buffer Type parameter is Solid, negative buffer amounts will cause a feature to be rejected.
If the Buffer Type parameter is Area (2D) and a negative buffer amount is too large to leave any part of a feature behind, the feature will be rejected.
If the Buffer Distance Units parameter is set to anything other than Ground Units (None), features without coordinate systems will be rejected.
| Buffer Type |
Specify whether to create Area (2D) or Solid buffers around input features. |
| Buffer Distance |
Each point on the boundary of the output area or solid is the specified amount, measured in the specified units, away from the input geometry.
These parameters are only enabled when the Buffer Type is Area (2D).
| End Cap Style |
When buffering a line, you can specify the end-cap style. As these diagrams illustrate, these caps can be Round (default) or Square, but you can also set this parameter to None. Round
Square
None
| Corner Style |
When buffering a line or area, you can specify the corner style. As the diagrams below illustrate, the corner styles can be Round (default), Bevel (chopped), or Miter (pointed). If Miter is used, a limit must be specified using the Miter Limit parameter. If a corner is too pointed for the miter limit, the corner will instead be bevelled. Round
Bevel
Miter
| Miter Limit |
Miter Limit This parameter controls how pointed a buffered corner can be before it is beveled. It is the highest value that the ratio of corner distance to offset is allowed to have before truncation occurs. A higher number allows for more extreme corner angles.
Miter Ratio = Corner distance / Offset
| Interpolation Angle |
This parameter controls the smoothness of the stroked arcs in the output buffer boundaries. It specifies what angles should be used to construct a circular arc. As this parameter decreases in value, the smoothness of the arc connectors increases. This parameter is used for the Round End Cap Style and the Round Corner Style. The value must be between 0 and 90 degrees. |
| Buffer Distance Units | When using Buffer Type of Area (2D), the units of the Buffer Distance may be specified as something other than ground units. This setting is designed for use with features in any valid coordinate system (geographic or other), and so may be used to create flexible workspaces that can buffer regardless of input coordinate systems and units. If a specific unit is chosen, it may reproject input features into the Dynamic Equal Distance projection, buffer them, then reproject them back into the original coordinate system. Input features without a coordinate system defined will be output via the Rejected port. |
| Dissolve On Attributes |
This parameter allows dissolving groups of buffered features with common values for the specified attributes. By default, no dissolving of buffered features takes place. |
| Dissolve On Attributes Mode |
Process At End (Blocking): This is the default behavior. Processing will only occur in this transformer once all input is present. Process When Dissolve Attributes Change (Advanced): This transformer will process input groups in order. Changes of the value of the Dissolve On Attributes parameter on the input stream will trigger processing on the currently accumulating group. This may improve overall speed (particularly with multiple, equally-sized groups), but could cause undesired behavior if input groups are not truly ordered. There are two typical reasons for using Process When Dissolve Attributes Change (Advanced) . The first is incoming data that is intended to be processed in groups (and is already so ordered). In this case, the structure dictates Dissolve On Attributes usage - not performance considerations. The second possible reason is potential performance gains. Performance gains are most likely when the data is already sorted (or read using a SQL ORDER BY statement) since less work is required of FME. If the data needs ordering, it can be sorted in the workspace (though the added processing overhead may negate any gains). Sorting becomes more difficult according to the number of data streams. Multiple streams of data could be almost impossible to sort into the correct order, since all features matching a Dissolve On Attributes value need to arrive before any features (of any feature type or dataset) belonging to the next group. In this case, using Dissolve On Attributes with Process At End (Blocking) may be the equivalent and simpler approach. Note: Multiple feature types and features from multiple datasets will not generally naturally occur in the correct order. As with many scenarios, testing different approaches in your workspace with your data is the only definitive way to identify performance gains. |
When enabled, adds a list attribute to the Buffered output features. This parameter is useful when using Dissolve On Attributes or if input features contain aggregates. Within each group or aggregate, within each dissolved region, attributes from an input feature with the largest area are stored at the head of the list, and no order is defined for the remaining elements.
| List Name |
Enter a name for the list attribute. Note: List attributes are not accessible from the output schema in Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used. |
| Add To List |
| Selected Attributes | Enabled when Add To List is set to Selected Attributes. Specify the attributes you wish to be included. |
This parameter is only enabled when the Buffer Type is Solid.
| Edge Resolution |
A round buffer is generated along all edges and corners for the solid. An approximation of a sphere is used to build up these edges. This resolution parameter determines the level of subdivision to use for this sphere. The sphere is generated using the quadrilateralized spherical cube mapping so the final sphere will consist of 6n^2 faces, for a value of n. The value must be an integer greater than 1. This buffer solid produces a better approximation of a uniform buffer distance with higher levels of subdivision, at the cost of performance of the buffer operations. |
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
Dependent on Group By parameter. If:
| Dependencies | |
| History | |
| Categories |
Search for all results about the Bufferer on the FME Community.
