The AttributeExposer makes unexposed attributes visible in Workbench so they can be used elsewhere in the workspace. This transformer is useful if you know features have an attribute, but that attribute is not currently showing in Workbench. For example:
Note: Expose attributes fme_basename and fme_dataset in the reader feature type or the FeatureReader transformer. These attributes are not read unless they are exposed in this manner.
You may enter the attribute names manually, or import attributes from any supported source dataset. Known attributes (including fme_ and format-specific attributes that are not currently exposed) can be selected from the drop-down menu.
This transformer only exposes the attribute in Workbench - it does not ensure that valid attribute names are being exposed. The input features are not modified in any way.
Once the attributes are exposed, they can be accessed elsewhere in the workspace.
In this example, we have a Parks dataset, and want to change the attribute names to match a desired schema. We route the Parks features into a SchemaMapper, which uses an external CSV file (lookup table) to map the attribute names to new ones.
The attribute map created in the SchemaMapper will take care of creating new attributes with the existing values, but Workbench does not yet know that the new attribute names exist on these features, and so cannot expose them in the workspace.
In the AttributeExposer parameters dialog, we add the names of the attributes we want to expose for use elsewhere in the workspace. The names could be entered manually, or imported using the Import button (and then, in this case, reading the names from the same CSV file used in the SchemaMapper).
The features are then sent into an AttributeManager, where we remove the old, unwanted names, and reorder the attributes.
Features with attributes.
Features with exposed attributes.
| Attributes to Expose |
Enter attribute names or choose them from the drop-down list (which provides access to fme_ and format-specific attributes). The order in which they appear in the list is the order in which they will appear in the Output port of the transformer. Import: Use this to import attribute names from any supported source dataset. |
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
| History | |
| Categories |
Search for all results about the AttributeExposer on the FME Community.
