PathSplitter
Decomposes a path feature into its component segments.
Note that for an input feature to be affected, its geometry itself must be a path; that is, areas whose boundaries are paths and aggregates containing paths will be unaffected.  The GeometryCoercer, DonutHoleExtractor, and Deaggregator may be used to prepare the geometries input to this transformer.
Each output feature will contain a copy of the source feature's attributes. Non-path input features will be output untouched.
Transformer Categories
Geometries
Technical History
Associated FME function or factory: DeaggregateFactory
Search FME Knowledge Center
