Deaggregator
Each output feature may keep a complete, unaltered copy of the source feature's attributes.
Flatten
Attribute Accumulation
In some cases, a feature's non-list attributes may share the same name as attributes that are generated by the Deaggregator. For example, consider a feature with a non-list attribute length and a list attribute somelist{0}.length, somelist{0}.kind, somelist{1}.length, somelist{1}.kind,... If somelist is exploded, the feature may contain two length attributes - one from the original, non-list attribute, and one from the somelist list attribute. If the generated attributes share the same name as a feature's original, non-list attributes, but are not geometry attributes that start with fme_, they are deemed conflicted.
Use the following parameters to specify which attributes to keep on the output features, and which attribute's values to maintain in case of conflicts.
Preserve Hierarchy
Example
Geometric Representation
Data Structure Representation
Transformer Categories
Attributes
Filters and Joins
Technical History
Associated FME function or factory: DeaggregateFactory
Search FME Knowledge Center
