SOSI GML Reader Parameters
Application Schema
- by Themes(default): Enables the SOSI GML Themes parameter.
- by XSD: This option enables the Application Schema parameter, where you can specify a different schema (other than the built-in themes).
Tip: When reading schema features or importing feature type definitions into the SOSI GML writer, the reader dataset parameter may be left unset.
Browse a list of the available SOSI GML themes. (Note that themes are based on the v4.6 schemas.)
Note: An explicit path to a different SOSI GML schema with the definitions for the appropriate theme or layer can be specified in the Application Schema parameter.
When the by XSD parameter is selected, this parameter specifies the location of the GML schema .xsd file.
Determines whether the reader should validate the specified dataset file.
Specifies how the reader obtains feature types:
- XSD Schema: FME reads feature types from the XSD.
- Dataset Only: FME reads feature types from the dataset.
- Dataset Only with Attributes Merged from XSD: FME reads feature types from the dataset, and includes any attributes in the XSD that are associated with a particular feature type.
This parameter can be used to tell the reader to ignore the schema files that are specified in the xsi:schemaLocation attribute of the root element in the dataset. This is particularly useful if the file locations specified in xsi:schemaLocation are not valid file paths.
This optional parameter instructs the reader to map FeatureCollection as an FME feature.
Values: gml:FeatureCollection | wfs:FeatureCollection
Usually, only one value is used within a dataset. Selecting both gml:FeatureCollection and wfs:FeatureCollection may cause a clash in feature type names when both GML and WFS schemas are loaded, since FME needs the feature type to be unique in a reader or writer.
If both values are required, you may need to set the Add XML Namespace Prefix to parameter to a value of Feature Types – this parameter adds the namespace prefix to the feature types to make them unique.
SRS/Geometry Parameters
Overrides the axis order when reading a coordinate tuple in a GML element.
Valid values for this parameter:
- 1,2
- 2,1
- 1,2,3
- 2,1,3
There is no default value for most GML formats; however, for IndoorGML, there is a default blank value (which is the same as 1,2,3).
For WFS 1.0, the value is assumed to be 1,2. For WFS 1.1.0 and 2.0.0, the SRS order is determined by the SRS specified. For example, the default axis order for EPSG:4326 is 2,1.
If the srsName in the GML document is set to urn:ogc:def:crs:EPSG:6.6.4326, and you know that the coordinate order in the GML document is lon-lat and not lat-lon order, set this parameter to 1,2 so that the reader reads the data in lon-lat order.
This parameter affects the interpretation of the start and end angles for gml:ArcByCenterPoint.
The parameter overrides the default interpretation for the 0 axis location and angle direction regardless of the dataset SRS.
By default, if the SRS axis order is 1,2 or 1,2,3, then the angle direction is assumed to run counterclockwise starting from the horizontal axis. Otherwise, when the x and y axes are flipped, the angles run clockwise starting from the vertical axis.
This parameter controls how segments in a path are joined together when the segments' end points are not connected:
- Inserting New Segment connects the path by inserting a new connecting segment between the original segments.
- Snapping End Points forces the first point of each segment to equal the last point of the previous segment.
Note: For backwards compatibility, Inserting New Segment is assumed when the Enforce Path Continuity By parameter is not present.
Feature Properties
Specifies whether the default and optional GML feature properties, name and description, should be read.
This parameter specifies whether the GML geometric properties should be represented as attributes in the FME feature type definitions.
In FME data features, the GML geometric properties are represented as a single named geometry – or, if multiple geometries are present, as an aggregate geometry with multiple named geometry components. The name and the position for these geometric elements can also be controlled through the GML User Attributes
- If this parameter is checked (which is the default), then the feature type definitions will contain the geometry names as attributes, and their type is set to xml_geometry. If an attribute X has its type set to xml_geometry, this attribute X becomes a placeholder in the feature type definition. It is a placeholder because actual data features for the feature type definitions will not have this attribute; instead, the data features will have a geometry named “X”.
- If this parameter is unchecked, then the feature type definition will not contain geometry names.
The FME feature type and/or attribute names may include the XML Namespace prefixes used in the GML application schema. The prefix will be separated from the names with an underscore.
By default, the prefixes are not added to the names. To include the prefixes in the feature types, select Feature Types. To include the prefixes in both the feature types and attributes select Feature Types and Attributes.
Setting this parameter to Feature Types is necessary when a GML dataset contains feature types with the same name in different namespaces.
The list of whitespace-separated QNames specified in this parameter defines properties that the reader should ignore while processing the GML application schemas.
To ignore property regardless of namespace, simply specify the local-part of the name. For example:
boundedBy name
will ignore all properties whose local name are boundedBy or name, regardless of their namespace.
A prefix in a QName should be present in the parsed XML schemas. If no corresponding URI namespace can be found for a prefix, then the prefix will be discarded. The QName will (as in the unprefixed case) apply to all properties with the same local-part, regardless of namespace.
For example:
gml:boundedBy identifier wrong-prefix:description
If a binding for the gml prefix can be found in the parsed schema, then only boundedBy properties with the same namespace URI as gml will be ignored; otherwise, every boundedBy property regardless of namespace will be ignored.
Every identifier property, regardless of namespace, will be ignored. Every description property regardless of namespace will also be ignored, since the parsed schema will not have a binding for the "wrong-prefix" prefix.
Feature Properties – Attribute Handling
Specifies whether GML properties that are defined as a complex type with complex content (that is, those that have embedded children elements) should be mapped as nested list attributes within FME features.
If the value is set to XML Fragments, then the complex properties with complex content are mapped as XML fragments.
Some complex properties, such as those that are recursively defined, cannot be mapped as nested lists. These complex properties will always be mapped as XML fragments, regardless of the setting for this parameter.
This optional parameter can control the depth of nested list attributes.
When this parameter is selected, the reader, in addition to mapping the GML geometry XML elements into FME geometries, will include these elements in FME attributes as XML fragments in the feature.
The FME geometry attributes are typed as xml_geometry in the feature type definition. In the group Version and XML Namespace Processing below, see the parameter Use Old Reader for GML v3.1.1 and v2.1.2 Documents.
This parameter is useful in the case of a GML geometry reading error, since the XML fragment representing the GML geometry will also be carried along in the same feature as an attribute.
Specifies whether GML properties that are mapped as XML fragments should be converted into XML documents.
The conversion will add missing namespace declarations to the fragments, it will maintain CDATA sections, and it will also prefix an XML header declaration to the fragment. Converting the XML fragments into XML documents allows XML-based parsers, e.g., XSLT and XQuery based processors, to further process the fragments.
This parameter specifies whether GML properties that are mapped as XML fragments should be flattened into nested attributes.
The flattening will only be applied to the data features carrying the XML fragments, hence the new flattened nested attributes will not be reflected in the FME feature type schema definitions.
These options are available for the flattened list attributes:
- Substitute Open List Brace: This directive specifies the character to use as the open brace for the flattened list attributes. The open brace defaults to a curly brace
{but any single character is accepted. - Substitute Close List Brace: This directive specifies the character to use as the close brace for the flattened list attributes. The close brace defaults to a curly brace
}but any single character is accepted. - Substitute Element List Separator: This directive specifies the string to use as the separator for components within the nested attributes. The nested attribute component separator defaults to a period (.) but any single character is accepted.
When selected, this parameter disables XML Namespace processing for the underlying XML parser.
Note that this may cause reading errors if the GML schema and the GML data use different prefixes for the same namespace URI. This parameter may be useful for datasets that are not XML-Namespace-valid.
Schema Attributes
- In a non-dynamic scenario, you can use this parameter to expose additional attributes on multiple feature types.
Use Search Envelope
Using the minimum and maximum x and y parameters, define a bounding box that will be used to filter the input features. Only features that intersect with the bounding box are returned.
If all four coordinates of the search envelope are specified as 0, the search envelope will be disabled.
When selected, this parameter removes any portions of imported features being read that are outside the Search Envelope.
The example below illustrates the results of the Search Envelope when Clip to Search Envelope is not selected (set to No) and when it is selected (set to Yes).
- No: Any features that cross the search envelope boundary will be read, including the portion that lies outside of the boundary.
- Yes: Any features that cross the search envelope boundary will be clipped at the boundary, and only the portion that lies inside the boundary will be read. The underlying function for the Clip to Search Envelope function is an intersection; however, when Clip to Search Envelope is selected, a clipping operation is also performed in addition to the intersection.
Use Network Authentication
This parameter is always visible in some formats, and visible in other formats only when the dataset is a URL.
Specify the authentication method to use when accessing a password-protected server.
- Basic: (default) Basic access authentication is designed to allow a client to provide credentials to a server on the assumption that the connection between them is trusted and secure. Note that any credentials passed from client to server can be easily intercepted through an insecure connection.
- Digest: Digest authentication is one of the agreed-upon methods a web server can use to negotiate credentials, such as username or password, with a user's web browser.
- NTLM: A challenge-response protocol that is used to provide compatibility with versions of Windows earlier than the Windows 2000 operating systems.
- Web Connection: Web connections provide a convenient and secure way to store and reuse previously established connection parameters. See Web Connection below.
- Single Sign-on: FME will use the credentials of the current user to authenticate the HTTP request. This authentication method currently works only on the Windows operating system.
Note: To access datasets using a proxy server, use the Network tools in FME Options. From the Workbench menu, select Tools > FME Options > Network. For more information, see "Network Proxy" in the FME Workbench Help.
