ASPRS LiDAR Data Exchange Format (LAS) Quick Facts
About Quick Facts Tables
Format Type Identifier
LAS
Reader/Writer
Both
Licensing Level
Professional and above
Dependencies
For reading and writing .lasd files, ArcGIS 3D Analyst Extension in ArcGIS Pro. The bit version (32-bit or 64-bit) must be the same for FME and ArcGIS.
Dataset Type
Reader: File
Writer: Folder
Feature Type
LAS or
<source_las_filename>
Typical File Extensions
  • .las
  • .laz
  • .zlas
  • .lasd – see note in Dependencies, above
Automated Translation Support
Yes
User-Defined Attributes
No
Coordinate System Support
Yes
Generic Color Support
No
Spatial Index
Never
Schema Required
Not Applicable
Transaction Support
No
Geometry Type Attribute
las_type
Encoding Support No
LAS Geometry Support
Geometry
Supported?
aggregate no
circles
no
circular arc
no
donut polygon
no
elliptical arc
no
ellipses
no
line
no
none
no
point
no
point cloud
yes
polygon
no
raster
no
solid
no
surface
no
text
no
z values
yes
LAS Point Cloud Components
Point Cloud Component Data Type Notes
x Int32
y Int32
z Int32
intensity UInt16
returns UInt8
number_of_returns UInt8
scan_direction UInt8
flight_line_edge UInt8
classification UInt8
angle Int8
file_marker UInt8 Allows for LAS flight-line based files to be combined into single files with more than one flight-line. Only supported in version 1.0.
user_data UInt8 (version 1.0) or UInt16 (version 1.1+)
point_source_id UInt16 Only supported in version 1.1+
gps_time Real64 Only supported in version 1.1+
color_red UInt8 Only supported in version 1.1+
color_green UInt8 Only supported in version 1.1+
color_blue UInt8 Only supported in version 1.1+
classification_flags UInt8
Indicates special characteristics associated with each point. This is a bit flag with the following values:
  • 0 - synthetic (created by a technique other than LIDAR collection)
  • 1 - key-point (should not be removed by thinning)
  • 2 - withheld (should not be included in processing)
  • 3 - overlap (this point is in the overlap region of two or more swaths)
Only supported in version 1.4.
scanner_channel UInt8 Indicates the channel (scanner head) of a multi-channel system. Only supported in version 1.4.
nir UInt16 The NIR (near infrared) value. Only supported in version 1.4.
