- Google KML Reader/Writer
- Google KML Quick Facts
 - Resource Traversal
 - Reader Parameters
 - Writer Parameters
 - Feature Types
 - Writer Pipelines
 - Atom Metadata
 - Style Management and Common Styles
 - Document Element Omission
 - Raw Text
 - Update Mode
 - Feature Representation
- KML Dataset Structure
 - File Structure
 - Identifying Elements
 - Documents and Folders
 - Tours
 - Extended Data
 - User Defined Schema
 - Layers and Feature Type Fanout
 - Feature Attributes
 - Geometry
 - 3D
 - Fixed Schema
 - Common Element Attributes
 - Common Format Attributes
 - NetworkLinkControl
 - Document
 - Folder
 - Placemark
 - ScreenOverlay
 - GroundOverlay
 - PhotoOverlay
 - NetworkLink
 - Style
 - StyleMap
 - Tour
 - AnimatedUpdate
 - FlyTo
 - SoundCue
 - TourControl
 - Wait
                                        The KML writer maintains a global 'registry' of style definitions. The style registry is used to simplify references to style elements, as well as to enable routing of style elements to external files.
